Ground for Gauge Cluster
Old Feb 18, 2009 | 02:34 AM
AJII's Avatar
Default Ground for Gauge Cluster
Is there some central place that the gauge cluster is grounded? ON random intervals, my Tach, Fuel Gauge, and Temp Gauges just die completely. They will stay off for a couple seconds and then come right back on? The Voltmeter and Speedo don't do it. Also, the batttery light comes on in the message center, but the battery is new.What could be the problem? ANY suggestions will be greatly appreciated!
Old Feb 18, 2009 | 05:21 AM
BigCountryx's Avatar
don't know what to tell you about the battery light, what's your voltage look like.... but the gauge problems sound like stepper motor issues. Serch for "stepper motor" and you should find plenty of reading.
Old Feb 18, 2009 | 12:10 PM
AJII's Avatar
It's not the cluster..I've swapped it out for a known good one and the problems are still there.
Old Feb 18, 2009 | 08:00 PM
budhayes3's Avatar
PT's Slowest Truck
Get your hands on a schematic (maybe someone can post one up), and see what is common to those gauges...could be a ground like you mentioned, a wire that's hanging on by a thread, or poor pin fitment at one of the connectors.
Old Feb 19, 2009 | 01:08 PM
AJII's Avatar
Thanks, hopefully someone can come through with a schematic.
Old Feb 21, 2009 | 11:26 PM
AJII's Avatar
Anyone?
Old Feb 22, 2009 | 02:46 AM
CashDudeHomie's Avatar
I've heard of this a few times on here. I think it was a body to chassis ground under the door.
Old Feb 22, 2009 | 02:57 AM
nonnieselman's Avatar
i remember reading about that a few times..
Unbolt the ground and clean the surfaces, reconnect and see what happens.
Old Feb 22, 2009 | 11:00 AM
AJII's Avatar
You guys are PURE GENIOUS! The connector was broken! Thanks so much!
andrewlong
Nov 9, 2016 09:38 AM
dantheman1540
Feb 24, 2016 09:56 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
zblee
Sep 17, 2015 07:58 AM
andrewlong
Sep 8, 2015 10:25 PM
