got the clunk
Old Dec 6, 2010 | 04:10 PM
40series's Avatar
Default got the clunk
hey fellas how dow u take the rear drive shaft down- today i removed the 2 u-joints straps - would'nt come down - wht am i doing wrong?- going to put some grease in the yoke
Old Dec 6, 2010 | 04:22 PM
BLUES MAN's Avatar
The House is Rockin'
on my single cab, i will remove the straps and use a pry-bar & LIGHTLY give it alittle help, not sure tho if it will work on your ext-cab...
Old Dec 6, 2010 | 04:33 PM
mhotrodscooter's Avatar
Put it in neutral, with the e-brake pressed. Use a pry-bar like said above. I hope your working on flat ground or on jack stands.
Old Dec 6, 2010 | 04:41 PM
dlt76028's Avatar
yep, neutral, ebrake, tap the driveshaft with a rubber mallet.
Old Dec 6, 2010 | 05:00 PM
iamkeniff's Avatar
prybar
are you pulling the whole thing out? block up the front tire, put the rear of the truck on jack stands or ramps and pull the 2 straps off and pry it forward. unbolt the 15mm nuts to take the carrier out and slip the whole thing out. pretty simple.
01silvy
Sep 26, 2015 10:20 PM
AUTOT3K
Aug 16, 2015 06:21 PM
Ferocity02
Aug 7, 2015 08:50 PM
CRASH 02
Nov 11, 2003 01:28 PM
