Going to look at a few 6.0's
Old May 2, 2006 | 04:22 PM
  #21
Zick's Avatar
Originally Posted by white1
3174's flow better, and have larger valves, but I havent figured out yet if the lowere compression and higher flow is better than the less flow higher compression. Ive been trying to find out though.
Well what I plan on doing is getting some LS6 heads from Patriot to raise the compression and keep the added flow, since the LS6 are exactly the same as the 317s but with small cc chambers.
Old May 2, 2006 | 04:42 PM
  #22
onebadrubi's Avatar
So having my 5.3l heads CNC'd and PP and all the other good headwork goodies wouldnt flow as good as the 317's?
Old May 2, 2006 | 10:29 PM
  #23
onebadrubi's Avatar
found a 6.0l in the classisfieds here with water damange for 650 plus shipping. He said it ran but a littl rough. Could the block be damaged at all? As long as the block is good I think i would be alright for my plans deffinately since im getting such a good deal at 650.
Old May 3, 2006 | 09:06 AM
  #24
white1's Avatar
No. The combustion chambers on the 5.3 heads are too small for the larger valves with out runing into shrouding problems.
Old May 3, 2006 | 12:12 PM
  #25
onebadrubi's Avatar
ok SO head wise the best way to go would have the 317's worked over? Or can I still use the 5.3l heads someway since the higher comp with help N/A
Old May 3, 2006 | 01:17 PM
  #26
white1's Avatar
Thats still what Im trying to figure out....Is the extra compression worth the loss of flow, and vice versa? I do know a few people running the 5.3 heads on 6l's though and they seem to be strong.
Old May 3, 2006 | 01:44 PM
  #27
onebadrubi's Avatar
your really confusing me. You just said I would run into shrouding problems running 5.3l heads on the 6.0? But then said you know of a few people doing it?
GMCtrk
18
Oct 6, 2015 03:48 PM
turbo6c3
Oct 5, 2015 06:11 PM
Cammed4ever
Sep 30, 2015 03:38 PM
trevorh1
Sep 27, 2015 08:47 PM
sTNT971
Sep 26, 2015 04:22 PM
