Going to the dyno this weekend to do some tuning, got some ?sss
Old Apr 16, 2008 | 11:36 AM
BlackGMC's Avatar
Resident Retard
Default Going to the dyno this weekend to do some tuning, got some ?sss
I booked some dyno time this weekend so I can get my timing dialed in and get a good baseline number before any of the engine mods I have planned begin, I will be doing the tuning but a tech will be runing the dyno...
I have a couple of questions thou....
I talked to the owner and we both decided to do 2nd gear pulls to be on the safe side, honestly I don't want to spin my truck up to 130+ in 3rd.... So this means I will be doing 2nd gear pulls with the TC unlocked. I don't want to use the Bidirectional controls to lock the TC cause it will limit my resolution on the scanner. Will I still get accurate readings doing it this way? I don't care about the how high the numbers will be cause we all know dynos are just tuning tools.... Also I was planning on using my Wideband for the AFR for my tuning purposes. For the amount I am paying I will get 6 pulls with time for adjustments inbetween, seems pretty decent to me...
Should be fun, I have never tuned on a dyno before, BTW it is a dynojet dyno.... Any advice or tips???
Old Apr 17, 2008 | 10:21 PM
TX Tahoe Z71's Avatar
Bump for you. Going to the dyno this weekend for the first time too!
Old Apr 17, 2008 | 11:15 PM
dirt track racer 81's Avatar
2nd gear pulls tc unlocked
Old Apr 18, 2008 | 12:35 AM
Stoichiometric's Avatar
It should be fun. When I had my 4.8 on the dyno with bolt ons, I had the timing up to 30+ degrees with out knock. I backed it down to 25 and made the best numbers. So my advise would be set the timing to 25, then spend the time working on the fuel.
Old Apr 18, 2008 | 03:27 PM
UBLUZIN03's Avatar
I might be dynoing my truck monday. What gear should i put it in? I was going to do 3rd..I have no tuning (except for a W4M tune) so i cant unlock/lock the converter..
Old Apr 18, 2008 | 04:37 PM
dlt76028's Avatar
do 3rd if you want it to be the most acurate. 1:1 ratio
Old Apr 18, 2008 | 04:51 PM
BlackGMC's Avatar
Resident Retard
I had to reschedule my dyno appointment, due to the hail, I have got some clean up to do in the yard. Hopefully I will be going in a few weeks...
Old Apr 18, 2008 | 04:53 PM
sorry but waitin 30 seconds from the motor to go from 3000 rpms to 6000 rpms is kinda nerve racking..only time i do a 3rd gear pull is with nitrous..nitrous plus second gear equals a pile of rubber behind the rollers...besides hes not going for numbers..just tuning..
Old Apr 18, 2008 | 06:33 PM
dlt76028's Avatar
i would agree, but with 4.10 gears mine sure doesnt take 30 seconds to get to 6400. i'd say most people do 3rd gear pulls.
Old Apr 18, 2008 | 07:43 PM
i was bein sarcastic..go ahead and take it to 6400 in 3rd..might regret it when the driveshaft flies out...been several people on here had that happen
..im not to worried about numbers anyways..never have been and never will..thats not what the intended purpose of a dyno anyways
pittman
Jan 19, 2016 07:06 AM
LARRY01Z28
Aug 1, 2015 10:15 PM
cammed06
Jul 24, 2015 12:09 PM
black6spdz
Jul 16, 2015 01:32 AM
NuckenFuts
Jul 9, 2015 08:45 AM
