GMT 800 (NBS) Drop Thread Specs and Pics Required
Old 11-15-2014, 11:45 PM
  #31
FFDP's Avatar
It's doesnt, because you add the strength back with the kit itself.
Research the c-notch and look at the parts. You bolt new metal onto the trucks frame or you can weld it all on when it's all put together. It's up the owner to do what he/she wants with it.
Old 11-16-2014, 11:20 AM
  #32
Slowest turbo build ever!
black00chev's Avatar
If you actually weld in a c-notch it will not weaken the frame at all. And there are plenty of people who just have it bolted in without issues.
Truck: 2000 ECSB Z71 4WD lowered 2/4
Tire Size: 285/50-20 in pictures. Currently has 265/60-18s which Ill get a pick up later today or tomorrow.
Front drop: 2" lowering keys cranked all the way up so CV angle is almost flat, slightly upward.
Rear drop: Lift blocks removed and 2" shackles
Shocks: Bilstein replacement shocks for stock 2003 AWD Silverado SS
Before (blocks removed)
After (keys and shackles)
Old 11-16-2014, 02:33 PM
  #33
N/ALS1's Avatar
I see everyone are running 20's and below. Anyone have 22's with a 2/4 drop? If so what size tires are y'all running?
Old 11-18-2014, 09:09 PM
  #34
Truck: 2001 ECSB 2WD lowered 4.5/7
Tire Size: 285/35-22 BFG KDW with SS replicas 22x10
Front: 2" McGaughy spindles 17"+, Hotchkis Progressive coil springs 2.5" on EC
Rear: Flip kit, 1" Belltech shackles, Cal Tracs
Shocks: BellTech Street Performance with shock extenders
Old 11-18-2014, 09:26 PM
  #35
GMCtrk's Avatar
Very nice man! I haven't seen you post around here in a long *** time.
Old 11-18-2014, 09:53 PM
  #36
I kinda of drop off the face of the earth for awhile and come back. Work has me traveling a lot. Not much time for play.
Old 11-19-2014, 01:10 AM
  #37
bigfatls6's Avatar
Did you recently post your wheels and lowering parts up for sell?
Old 11-19-2014, 07:24 AM
  #38
Yes, I did. I live out in the country now where the roads suck, and I can't get much use out of my truck anymore. Considering putting a mild lift on it. That should be a change! Haven't had much interest in the parts yet, so we will see if I actually go through with it.
Old 11-19-2014, 07:25 AM
  #39
N/ALS1's Avatar
Sleek do you have any rubbing issues or are the fender wells rolled?
Old 11-19-2014, 07:41 AM
  #40
Front and rear fenders are cut and rolled. Still rubs the inside of the driver's side top of the wheel well if I hit a modest bump.
Quick Reply: GMT 800 (NBS) Drop Thread Specs and Pics Required
