GMC Fog light kit ?'s
Old Mar 15, 2006 | 07:46 PM
BlackGMC's Avatar
Resident Retard
Default GMC Fog light kit ?'s
I just bought the GMc factory fog light kit and hooked everything up twice but the lights don't work. Does anyone have any ideas?
Old Mar 15, 2006 | 07:48 PM
Midnight's Avatar
You have to take it to the dealership or find someone with a tech 2 to tell the computer that it has foglights now. Takes about 3 minutes but you have to tell the computer that it has the foglights in now, otherwise it won't work.
Old Mar 15, 2006 | 08:08 PM
BlackGMC's Avatar
Resident Retard
The kit said that I don't have to reprogram anything but from what your saying I do. Damn marketing bull****.
Do you know if the dealership will charge anything to do that?
Thanks
Old Mar 15, 2006 | 08:18 PM
Midnight's Avatar
Im not sure, maybe depending on if you are a good customer or not lol. I worked there at the time so I had a buddy do it. They might not charge you cause its such a little thing to do.
Old Mar 16, 2006 | 08:59 AM
Nick99Chevy's Avatar
Thanks
I've never seen an 03+ that had to have them programmed.
Old Mar 16, 2006 | 09:11 AM
BlackGMC's Avatar
Resident Retard
I just contacted the dealership and they said that it does not have to be programed, so I still don't know what I need to do. Perhaps I don't have the wire in the fuse/relay box under the hood attached properly. I followed the directions and even took it apart twice trouble shooting. Any ideas?
Old Mar 16, 2006 | 11:15 AM
NBred94's Avatar
Not trying to insult anyone's intelligence by bringing up something elementary, but did the kit come with the dash switch and everything? I know that my fog lights will not turn on unless the headlights are on and I actually hit the button on the dash. I was just thinking if the factory wiring was used, that something in there might need to be changed such that the circuit is completed.
Just a thought, I may be way off.
Old Mar 16, 2006 | 03:47 PM
BlackGMC's Avatar
Resident Retard
could someone please look and see what kinda of relay you have on your fog lights it came witha 7866. perhaps it is the wrong relay or it is bad.
Old Mar 17, 2006 | 08:24 AM
Nick™'s Avatar
Default did it this week:
I just did the install on my 03 silverado (same wiring) this week (2 days ago :lol)
the relay goes in the slot as described on the cover of the fuse panel, it's the same relay as all the other small one's in the same panel and faces the same direction. When you remove the "forward lighting harness", when looking at the bottom side of the plug (side with the wires coming out) the hole you will want is: standing at the driver's fender - top row, and I belive 3rd hole. Also verify good ground, where did you pull a ground from? the frame of these trucks has a wax coating that will prevent it without scraping....
I had a problem at first, my trouble shooting technique is as follows:
plug in driver side lamp (leave pass. side off so you can move the harness around), with the pin in the fuse panel switch ignition on and move to underhood, grab ground wire (disconnected) and touch to (-) terminal on battery, if it works this way you had a bad ground, if not then your pin is in the wrong hole. I used an existing ground off the frame directly in front of the center of the motor on the top of a crossbrace, I had to add about 3" of wire to reach it but that beat drilling a new hole.
edit:
and the dealer reprogram is not required for 03+ as stated earlier
Old Mar 17, 2006 | 09:24 AM
BlackGMC's Avatar
Resident Retard
I tried connecting the positive terminal that goes into the fuse box directly to the battery and the lights came on. So there is no problem with the lights or the ground. However the relay that came with the kit is a 5-pin relay and it is a different number than all the rest of the 4-pin relays in the box. So I am thinking maybe the relay is wrong. I am going to try using my voltmeter today to trouble shoot the problem later on today after work.
So your saying the relay should all be the same in the fuse box?
