GM Parts Thread
Old Nov 26, 2008 | 04:42 AM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Default GM Parts Thread
First of all I would like to thank (CHEVRACER83) for suppling the part numbers to make this possible. Also I would like to thank (mcfarlnd) for doing the first 88 pages.
Engine parts:
Remanufactured GM Gen III crate engines
12491851 - 4.8 LR4
12491854 - 5.3 LM7/L59
12491357 - 6.0 LQ4
12491860 - 6.0 LQ9
LQ4
MAIN BOLT 12560272 QTY 10
MAIN BOLT/STUD 12560273 QTY 10
MAIN SIDE BOLT 12556127
LS2
CAM GEAR 12586481
CRANK GEAR 12556582
CHAIN 12586482
Vortech 6000 3 piece engine cover
CENTER - 12579166
DRVR SIDE - 12597908
PASS SIDE - 12574573
12499228 - GM Cam swap kit
12570623 - Oil filler tube
88894339 - LS6 intake manifold w/o EGR
12552344 - LS6 intake manifold bolts
12568002 - ls6 valley cover:
12573109 - ls6 valley cover pcv tube assm
12586484 - ls6 springs (2002)
12556705 - 97 Corvette fuelrail
12554677 - 97 Corvette fuel regulator
12554679 - The Clips that hold the injectors to the vette fuel rail
24500246 - Clip that holds the fuel regulator to the vette fuel rail
16040609 - 2 BAR MAP sensor
12580698 - 2 bar MAP LSX engines
12223861 – 3 bar sensor
LS2 COILS ARE 2 DESIGNS.
12573190 - ROUND SHAPED COILS
12570616 - SQUARE SHAPED COILS
05+ efans
89023365 - Shroud Kit
89023367 - Lh Fan Blade
89023366 - Rh Fan Blade
89023368 - Motor (2 Needed)
89023369 - Motor Clips (2 Needed)
88987983 - conn. for motors
15216055 – Relay Harness
11516931 - SCREW QTY 6 2 EACH MOTOR 2 TO HOLD TO RAD SUPPORT
22722593 - CLIP QTY 2 LOOKS LIKE ATTATCHES TO END OF MOTOR
12584727 - L92 block
12603910 - L92 complete engine
12600767 – L92 Water pump
89018058 - L92 spark plug wires
12499225 - LS7 lifter (Kit of 16)
12577215 - bolts for GEN III valve covers x8 REQ
89017412 - starter for a 01 suburban 6.0L 4l80e 4x4
12574927 - 8.1 ltr injector
02 5.3
12574294 - timing cover gskt
12588372 - H20 pump gskts
12585673 - crank seal
12557840 - balancer bolt
12560696 - valve cover gskt
12482062 - valve seals - exhaust - ea.
12482063 - valve seals - intake - ea.
12565312 - sodium filled exhaust valve
99 5.3 piston
88894404 - Standard
88894405 - .5 mm overbore
00 5.3
12557752 - Oil pick up tube o-ring w/o locator groove
12584922 - Oil pick up tube o-ring w/ locator groove
12575329 - cyl head gskt - ea
12498545 - Tty head bolts 2 kits req.
89017589 - intake gasket kit for 99 5.3
12589227 - All LQ4 and LQ9 head gaskets 2 req.
03 lq4 piston
89017237 - 2nd design fixed piston, pin pressed on
89017238 - 2nd design .5 mm overbore
88944004 - 1st design .5mm overbore w/pin
12565397 - front O2 sensors for a 01 Suburban 6.0
2724966 METAL WASHER WITH ATTATCHED RUBBER O RING (gasket that connects the A/C lines the compressor)
Lsx valve covers :
drv side: 12570427 (includes bolts, grommets and gasgets)
pass side: 12582224 (includes bolts, grommets and gasgets)
3 piece engine cover for Denali
12574573
12579166
15006417
03-06 Denali
RESERVOIR 12487670
CAP 25731418
12561211 - IS FOR LQ9 AND LS1 crank sensor
12560228 - IS FOR LQ9 AND LS1 cam sensor
12570790 - ls2 90mm vette dbw tb
12558081 - LS head dowells
25318411 - 04 5.3 MAF
01 5.3
12586482 - timing chain
12576407 - cam gear
12556582 - crank gear
12589867 - knock sensor
52487603 – radiator 34X17 1/2 X 1 1/8 W/ENG & TRANS CLR INCL DRAN ****.
Low_LSX's Avatar
DRIVETRAIN
5 speed clutch pedal assembley
from a 99/00 new bodystyle silverado 4.8L
15713209 - little support bracket for the pedal assembly
15027983 - this is the pedal assembly
15711228 - shift boot
99-02 2wd GM truck
15233111 - Front Hub Assembly
INNER TIE ROD END KITS 19152329 NEED (2)
18047512 - Hydro boosted mast cyl for 4 wheel disk ss
03+ power steering pump and the supply and return hydraulic lines to the master cylinder
PUMP 15909826
HOSES/PIPES
15295840
15844952
15764127
15295836
88980513 - radiator support for a 99-02 silverado
12458118 - trans temp sender for a T56
12479056 - 4.10 for the 8.5/8.6 rear
26038848 - 3.08 for the 8.5/8.6 rear
Driveshaft ujoint straps and bolts – 1/2 ton tahoe
07846740 - straps. qty 2 needed.
15734903 - bolts. qty 4 needed.
03 sstb brake pads
88964423 - frt GM pads
19122385 - rr GM pads
AcDelco durastop alternative - (basically GM pads brown boxed - cheaper, but just as good. BTW these are ceramics, like all gm pads.) -
19108013 - frt
19108014 – rr
2-Piston Rear Brake calipers for an 99-02 Tahoe:
REGULAR VACUM BOOSTED BRAKES
LH 88982595
RH 88982596
IF YOU HAVE HYDRO BOOSTED BRAKES
LH 18040101
RH 18040100
15745846 - nv3500 tranny disk and pressure plate
4 bolts and 2 straps that hold in the drivshaft/U joint.
07846740 - straps 2 req.
15734903 - bolts 4req.
15012506 - Caliper bracket bolt
15741709 - Manual trans crossmember
11518875 - 2wd u bolts
12551367 - 4l80e flywheel
15000206 - 4l80e Torque Converter Shield
12563532 - Spacer MUST BE USED WHEN REPLACING ABOVE FLYWHEEL
12162104 - IS THE CONNECTOR FOR THE VSS ON A 2001 4L80E (MT1) TRANS
THE PC< TERMINALS ARE AS FOLLOWS...
FOR 20 GA WIRE - 12084913
FOR 18 GA WIRE – 12084912
15246518 – GM Battery Relocation KIT
15806746 - COMPLETE 14 BOLT 6 LUG 4.10 RATIO DRUM BRAKES
15806743 - COMPLETE 14 BOLT 6 LUG 3.73 RATIO DRUM BRAKES
24229658 - m30 4l60e trans deep pan w/o drain plug
24213991 - 4L60E tranny drain plug
15998641 – 99-02 4l60e Crossmember
04 VETTE
8642079 - 2ND APPLY SERVO
8642478 - 4TH APPLY SERVO
12580709 - Ls2 flexplate 06 TBSS
12553332 - STOCK 6.0 FLEXPLATE BOLTS FOR A 2005 6.0
15000206 - TRANS CONVERTER COVER 2002 4L80E
99-02
12577903 - oil cooler block off plate
Old Nov 26, 2008 | 04:43 AM
Low_LSX's Avatar
BODY
12335700 - 03-07 bowtie grill emblem
92162158 - GTO 6.0 emblem
15825691 - 07 DENALI door emblem
01-02 HD Grille - 15088290 and bumper cap - 15746399
99-06 weatherstripping that sticks to the bed, between the bed and cab - 15097643
Sierra C3 badges:
15058254 "C3"
15707451 "sierra"
15268796 - VortecMax emblem
VICTORY RED DOOR HANDLES
15015969 - LH
15015970 – RH
STORM GRAY METALLIC DOOR HANDELS
15015959 - LH
15015960 - RH
19150859 - 99+ tailgate handle bezel
Black painted tailgate handle
15188001 - handle
15187998 – bezel
12477935 - 06 GMC paintable front bumper cap
12335963 - 06 GMC front lower valance w/fog lamps
19130787 - 06 GMC chrome grille
15224192 - 03+ GMC's Front 2" air dam
15901510 - GMC SIERRA DENALI BUMPER
19130786 - Non chrome gmc grille (SIERRA C3)
19130787 - 02 GMC GRILL chrome
19130786 - 02 GMC GRILL grey
11517887 - 02 GMC GRILL 10 mm bolt goes through the grill shell to core support 5REQ
12477935 – 99-02 GMC Bumper Pad
OBS 2004
15764320 - RETAINERS FOR MAIN "BIG PART" OF GRILL
15002520 - RETAINERS FOR CHROME GRILLE BARS BETWEEN LIGHTS
NBS 04
15078238 - RETAINERS FOR MAIN PART OF GRILL
15768343 - RETAINERS AT END OF CHROME BARS BETWEEN LIGHTS
Black lower valance (2" strip or so) added in 05
10386199 - 2wd
10386198 - 4wd
05-up lower valance extension
10386199 - 2wd
10386198 - 4wd
15224192 - frt air dam (2 inch strip
15709110 - 99-02 body DEFLECTOR ASM-FRT AIR (HIGH AIR FLOW) *CHARCOAL
99-02 Silverado/Sierra Rear Bumper plastics
Center bumper step pad 12335696
LH bumper step pad 15738017
RH bumper step pad 15738018
upper tailgate cap 15046605
that’s the one where the top is flat and goes back an inch or 2, and is textured like a step
15138277 - Silver birch SS grille shell (03-05 SS)
19122197 - 06-07 classic ss grille (paintable)
15197873 - SS tailgate spoiler
15082619 - License plate light assy for a SS rear bumper
15116616 - SS chrome center caps
15197885 - SS silver center caps
19120553 - SPOILER KIT (Intimidator SS Silverado tailgate spoiler)
19150310 - chrome bumper (03+ Chevy)
89025820 - smooth bumper cap (03+ Chevy)
88944419 - pass side fender (03+ Chevy) –
Mirrors (fully loaded) With power, heat, turn signal, dimming, puddle light) Its the DL3 option.
15198009 - LH
15198010 - RH
11610010 - The smallest bolt on the top of the fender on the driver's side that goes to the bracket between the core support and the driver's side fender over the battery.
p/n
Here is the 99-02 p/n for the chrome body molding
15744371 - door
15744375 - cab
15744376 - bed
2000 chevy fog lamps
10368476 & 10368477
12499673 – 07 Silverado classic fog light kit
12177236 - flasher/blinker relay module for the trailor light system on a 2003 Silverado.
15216042 - 2006 1500 WITH FOG LIGHTS AND E-FANS front wiring harness
07 sierra denali moldings BLACK SMOOTH
15001878 - FRONT BOTH SIDES
15005455 - REAR BOTH SIDES
02 tahoe Rear lift gate hydraulic arms
15766375 - LH SIDE
15766376 - RH SIDE
15047200- upper control arms for my truck 2001 4wd
15745931....99-02 HD HOOD
15151978 - tailgate cap screws/fasteners
11518684 - IS THE NUT THAT GOES INTO THE BED
O7nnbs CHEVY
25810706 - GRILLE BLACK
15836962 - BUMPER BAR... PAINT TO MATCH
O7nnbs GMC
25810705 - GRILLE BLACK
15901510 - BUMPER BAR ONLY ONE IT SHOWS
15940214 - Body Control Module
2007 Cadillac EXT or ESV Window Chrome trim
15850545- FRONT LH
15850546- FRONT RH
15850541- REAR LH
15850542- REAR RH
Z71 factory fender flares for indigo blue:
FRONT
LH 88979839
RH 88979838
REAR
LH 19120011
RH 19120012
03-06 Silverado
89025820 - Upper paintable cap
S10 Windshield Trim:
UPPER 15726940
LH 15724145
RH 15724146
S10 Extreme Parts:
15034723 - lower front bumper valance
5977934 - left and right fog lights with mounting brackets and hardware
DISCARD BRACKETS THAT COME WITH FOGLAMPS
26041014 - pitman arm
26041013 - idler arm
12386615 - center link
IN: 26054934 OUT: 26054936 - inner and outer tie rods
15149543 - driver side motor mount...the rubber part
15726710 - driver side door switch for interior lights...mounted on side of dash board
88985333 - power steering pump
88996477 - reverse light switch
03-06
15216042 - THE FWD LAMP HARNESS
07-08 Chevy Suburban
15173619 - GM Backup Camera
03-06 Front and rear smooth fleet side fender flares:
FR 15829687
FL 15829688
RL 19120011
RR 19120012
03-06 Silverado:
10386198 - THAT IS THE PLASTIC PIECE THAT GOES ON THE BOTTOM OF THE VALANCE.
15758072 - Front chrome bumper for a 02 gmc sierra 1500
Old Nov 26, 2008 | 04:44 AM
Low_LSX's Avatar
INTERIOR
Steering wheel switches
01999442 - program and source buttons
21997738 - trip/fuel buttons
21997739 - personalization
01999443 - seek/volume
Escalade platinum a/c vent assemblies -
far left outlet - 15784733
center - 10393267
right 2 outlets - 15102493
15112849 - 06 Escalade cluster
15713209 - This is a little support bracket for the pedal assembly
Lower seat heating element on the driver side in a 2003 Silverado
PART NUMBER 88940288
Gmc window regulator
19120847 RH
19120846 LH
19155774 FLOOR MAT TITANIUM COLOR... W/GMC LOGO REG CAB
15195778 FLOOR MAT TITANIUM COLOR... W/GMC LOGO EXT CAB OR CREW CAB
2002 Escalade
9379907 - Ac **** for escalade
15062684 - head lamp switch for escalade
26075107 - Cadillac Escalade LEATHER SHIFTER HANDLE
Escalade platnium a/c vents:
LH DRVR 15207881
RH DRVR 10368830
LH & RH PASS 15102493
2002 Escalade/Denali INFO DISPLAY Harness
12171873 IT IS ACTUALLY A SMALL HARNESS.... CALLED CONSOLE HARNESS EXTENSION
99-02 Denali window switches
15151865 and 15151866
99-02 GM Trucks/SUVs
26093753 - Rubber boot that goes on the gear selector into the steering Colum
99-02 dark gray
B PILLARS LH 89023048 RH 89023049
SILL PLATES LH 15046500 RH 15046495
99-02 Silverado Pewter Full center console:
15759808 I/P EXTENSION BEZEL
15072006 I/P EXTENSION
15958735 COMPARTMENT I/P EXT
12475013 COVER FLR CNSL
12475051 PANEL REAR COVER
12475013 BODY/ FLR CNSL
12472734 CUPHOLDER FLR CNSL
12476288 FRNT CVR
15034206 BRACKET FLR MT CNSL
00-02 SILVERADO WINDOW REGULATOR motor LH
88981018 - THE MOTOR
19120846 - THE REGULATOR
03-06 Silverado
15076588 - FOG LAMP SWITCH WITH CARGO LIGHT SWITCH
TIE ROD ENDS 26079801
COAT HOOKS 15760164
VISOR HOOKS 15052538
SWITCH PANELS
LH 89045124
RH 89045126
RECLINE LEVER
LH 88941654
RH 88941655
2001 GMC Denali:
12171873 IS THE HARNESS FOR THE ACCESSORIES IN THE CONSOLE (INCL DIC)
THE BEZEL FOR A 2000 WITH A MANUAL TCASE IS
PEWTER - 15711298
OAK - 15711300
GRAPHITE - 15711301
15166054 - DOME LAMP
89023048 – Interior speaker panel in Graphite
Old Nov 26, 2008 | 07:17 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
More from A.J.
Factory Silverado SS body cladding, front & rear bumper:
89038688 - Sport Wheel kit (P30 option) 20x8.5”
15197885 - Sport Wheel hubcap
12335659 - Front bumper fascia (unpainted)
12335660 - Rear bumper fascia (unpainted)
12335692 - Rear bumper fascia upper step pad
15197888 - Rear bumper impact bar
18045936 - Rear disc brake pads
12335767 - Front left brake caliper duct
12335766 - Front right brake caliper duct
12335769 - Radiator grille emblem
15178666 - Name plate (SS emblem) need 3 total
1 for pickup box end-gate
1 for each door
15192457 - Muffler with exhaust and tailpipe
15178226 - Left front fender lower rear molding unpainted
15178227 - Right front fender lower rear molding unpainted
88979994 - Driver side door lower molding unpainted
88979995 - Passenger side door lower molding unpainted
88979996 - Left side rear door lower molding unpainted
88979997 - Right side rear door lower molding unpainted
15178226 - Left rear of cab lower molding unpainted
15178227 - Right rear of cab lower molding unpainted
88980187 - Fender molding in front of rear wheel opening unpainted
88980188 - Fender molding in front of rear wheel opening unpainted
88944467 - Fender molding behind rear wheel opening unpainted
88980189 - Fender molding behind rear wheel opening unpainted
15178282 - End-gate molding for pickup box unpainted
88977071 - Seat head restraint (head rest) pewter
88977070 - Seat head restraint (head rest) neutral
15197873 - End-gate pickup box Spoiler unpainted
Old Nov 28, 2008 | 04:07 PM
trever1t's Avatar
#42 Injectors: Delphi Multec 2 OE Part #25176061
4/6 Drop: QA1 12-way Adjustable Shocks
Fronts are for stock length or DJM control arms. (part number: TC1958P + BAR350K)
Rears are for 6" drop - Includes shock extenders.(part number: TC1576P)
If you have part #'s you'd like added to the list please contact Low_LQ4 or myself
Old Nov 28, 2008 | 04:35 PM
trever1t's Avatar
Courtesy of hirdlej
HEAD GASKET LIST....
Old Nov 29, 2008 | 08:59 PM
trever1t's Avatar
03-06 Center Console
SS Cladding
Old Dec 2, 2008 | 10:58 PM
trever1t's Avatar
Thanks to 1FastBrick
ALL Gen lll Engine's Gasket and Seals
#12574294 -Front Timing Cover Gasket
#12585673 -Front Timing Cover Crank Seal
#12574293 -Rear Cover Gasket
#89060436 -Rear Cover Main Seal
#12558760 -Valley Cover Gasket
#12558177 -Valley Cover Knock Sensor Seal SOLD AS A SINGLE
#12560696 -Valve Cover Gasket SOLD AS A SINGLE
#12577215 -Valve Cover Bolt with Groment SOLD AS A SINGLE
#12575329 -4.8L/5.3L GM MLS Head Gasket SOLD AS A SINGLE
#12589227 -6.0L GM MLS Head Gasket SAME for LQ4, LQ9, LS2 SOLD AS A SINGLE
#12498543 -LS1 5.7L GM Graphite Head Gasket 97-01 LS1/LS6 SOLD AS A SINGLE
#12498544 -LS1 5.7L GM MLS Head gasket 02-04 KIT W/ 2 HEAD GASKETS
#12589226 -LS1 5.7L GM MLS Head gasket 02-04 SOLD AS A SINGLE
#12582179 -LS7 GM MLS Head Gasket SOLD AS A SINGLE
#12610046 -LS3/L92 GM MLS Head Gasket SOLD AS A SINGLE
#12557752 -Oil Pump Pick up O ring w/o locator groove
#12584922 -Oil Pump Pick up O ring w/ locator groove-RED in Color
#12482062 -Exahust Valve Seal SOLD AS A SINGLE
#12482063 -Intake Valve Seal SOLD AS A SINGLE
#12610311 -Water Pump Gasket SOLD AS A SINGLE
#89060413 -Truck Intake manifold Gaskets-W/ GREEN Seals
#12587147 -Injector Seal Kit
Gasket and Seal Kits
#12499228 -LS Series Engine Cam Swap Installation KIT Includes front engine cover gasket, water pump gasket, intake manifold gaskets, valve cover gaskets, balancer bolt, and front seal.
#12499217 -LS1 5.7L Cylinder Head Installation Kit The kit includes two head gaskets, two valve cover gaskets, eight manifold gaskets, two exhaust manifold gaskets, two intake manifold-to-block seals, 16 cylinder head bolts, and 14 cylinder head bolt/screws.
#12499234 -LS1/LS6 Complete Piston Ring Set Standard Bore Size 3.898
#12499235 -5.3L/4.8L Complete Piston Ring Set 99-05 Standard BoreSize 3.78
#12499236 -6.0L LQ4/LQ9 Complete Piston Ring Set 99-05 Standard Bore Size 4.00
Sensors
#12601822 -Replacement Knock Sensor Harness for Truck
#12102621 -Just the Knock Sensor Connector Pig Tail
#12589867 -Knock Sensor SOLD AS A SINGLE
Internals/ External Part Numbers
#17122490 -GM LS7 Roller lifter This Number is for a single Lifter, They are packaged in sets of 8
#12499225 -GM LS7 Lifter Pack of 16 to 7000 RPM This is the number for a package of 16
#88958689 -GM High RPM Lifters Pack of 16 to 8000 RPM
#12586484 -Yellow Z06 Valve Spring Part number for 1 Spring
#12499224 -Yellow Z06 Valve Spring Set of 16 Springs
#10166344 -Retainer for all Factory springs SOLD AS A SINGLE
#10166345 -Keeper SOLD AS A SINGLE SET FOR ONE VALVE
#12551162 -Lifter Guide, LS1/LS6 SOLD AS A SINGLE
#12595365 -Lifter Guide, LS2/LS7 SOLD AS A SINGLE
#12551163 -Lifter Guide Bolt SOLD AS A SINGLE
#12571595 -L92 Hydraulic Roller Two-Stage Valve Lifter SOLD AS A SINGLE
#17122490 -L92 Hydraulic Roller Two-Stage Valve Lifter SOLD AS A SINGLE
#12571596 -L92 Front Lifter Guide SOLD AS A SINGLE
#12571608 -L92 Rear Lifter Guide SOLD AS A SINGLE
#12586482 -GM HD Timing Chain
#12565308 -02-04 LS6 Cam
#12571251 -05-07 LS7 Cam
#12553118 -LS1 LS2 Balancer for car aplications
#12576652 -TRUCK Balancer for 4.8 5.3 6.0
#12557840 -Balancer bolt
#12586665 -OIL Pump
#89018166 -Truck Water Pump
#12556127 -Cross Bolts though the block into the side's of the main caps SOLD AS A SINGLE
#12570326 -Cylinder Head Dowl Locator SOLD AS A SINGLE
#89060420 -Fuel Presure Regulator Truck Return style fuel systems
#88862586 -EOS GM's Engine Assemebly Lube Oil Additive 1 Quart
#12559353 -24x Reluctor wheel
#12563918 -Truck Dipstick Tube 99-07
#12558684 -Truck Dipstick 99-01
#12610053 -Truck Dipstick 02-07
This is what I found for Head Bolts in another post.... 99-03... I am NOT sure on 04-UP
OK THERE ARE 3 DIFFERENT SIZE BOLTS.
#12558840 -SHORT...YOU NEED 10 Total
#12560745 -MED... YOU NEED 4 Total
#11588291 -LONG... YOU NEED 16 Total
Those are the totals needed to do Both heads.
From experince, I have found it is More expensive to get them individual through the dealer, then it is to get a Head bolt Kit from some one...
#12498545 -Should be a Head bolt Kit for 97-03 ONE HEAD with the above 3 part numbers in it. YOU NEED 2 KITS
#17800568 -Should be a Head bolt Kit for 04-UP ONE HEAD Not Sure On Individual part numbers. YOU NEED 2 KITS
GM Remanufactured LongBlock's
#12491851 - 4.8 LR4
#12491854 - 5.3 LM7/L59
#12491357 - 6.0 LQ4
#12491860 - 6.0 LQ9
Old Dec 7, 2008 | 09:43 AM
trever1t's Avatar
4L80E Conversion part number:
15000206 - Converter dust cover
12551367 - 6.0 Flexplate
12563532 - Crank Spacer
12553332 - Flexplate bolts (6 required)
15198439 - 4L80E Dipstick tube
15183801 - 4L80E Dipstick
15013290 - 4L80E Shift cable bracket at transmission
11589040 - 4L60/65/70/80/85E Toque converter bolt (6 required)
The tranny mount can be re-used because they use the same part number (15767858)
Or at SpeedENG website
http://speed-eng.com/store/4l80e-con...1996_1997.html
