Gm Part #anyone?
#801
Originally Posted by CHEVRACER83
24229658 deep w/o drain plug.... m30 4l60e trans
#802
19155774 FLOOR MAT TITANIUM COLOR... W/GMC LOGO EXT CAB OR CREW CAB
15195778 FLOOR MAT TITANIUM COLOR... W/GMC LOGO REG CAB
Thanks
#803
Originally Posted by niugnep
Sorry to bother you again, local stealership is telling me that is backwards, ie 774 is reg cab and 778 is cre/ext....could you double check please?
Thanks
Thanks
NO BOTHER... IM SORRY ABOUT TAHT I WAS RUNNING THE BODY CODES AND WHEN I WROTE IT DOWN I TRANSPOSED THE 2.... THAT IS CORRECT... 778 IS CREW CAB/ EXT CAB, AND 774 IS REGULAR CAB... IM SO SORRY MAN...
#804
Originally Posted by SlvrSierra4.8
Awesome man, I appreciate the help. I'm guessing they do not make one w/ a drain plug then is that correct?
NO THE ONLY ONE WITH A DRAIN PLUG IS THE 80E
#805
Wonder why they are different, I guess they would be different floorpans you'd think they would try to shape them the same so everything fits the same.
Just wait until I decide to drop a six seed auto into this thing....LOL Then you're gonna be a busy man!!!
#806
Can you compare the part numbers for the e-brake cables for the following VINs? If the part numbers are different, can you post the part number for the drum cabels? I just need the cabels that go from the back of the brakes to where they come together under under the cab. Both the VIN's are for 2wd reg cabs. Thanks in advance.
1GCEC14X34Z200401 (Disk Rear End)
3GCEC14V96G178762 (Drum Rear End)
Next time I'm down in So Cal, I owe you a beer
#807
I am thinking the drum brake lines are longer if I am not mistaken??
When I looked at my setup the rear drum ebrake cable seems longer I just need a verification if the end of that cables from a drum brake will slide on the disk brake bracket?
#808
BEZEL WILL COME BLACK... 19150499
RED HANDLE 15188002
LOOKED UP FOR 2005 SS
RED HANDLE 15188002
Thanks man, how about all the plastic pieces for the both front and rear bumpers with the front air dam having fog light holes cut out. for a 05
#809
YES THEY ARE DIFFERENT.... THE DRUM CABLES ARE...
15222144 LH
15204020 RH
GOOD LUCK BRO
