Gm Part #anyone?
Old Nov 7, 2012 | 07:58 PM
  #2501
JDC's Avatar
JDC
Default Power Seat Panel
I have a set of 2006 chev power seats the driver seat is missing the screws that hold the power contol panel on the side. Cant find the right length at the hardware stores. Would you have a part # for these screws. Thanks. I only have the seats no vin #
Old Nov 7, 2012 | 08:05 PM
  #2502
mcfarlnd's Avatar
Un-Registered User
Originally Posted by Robert91RS
REAR(x2)# 12474021
Thanks Robert!
Old Nov 8, 2012 | 08:04 AM
  #2503
Robert91RS's Avatar
The trim bezel is fixed to the seat by bolt pt# 88941745 and its dimensions are M3.5x1.3x45mm long. The switch is held to that trim bezel by pt# 11609465 and its dimensions are M4.2x1.4x18mm long.
Old Nov 9, 2012 | 06:40 AM
  #2504
JDC's Avatar
JDC
Thanks for the #'s Robert the little bastards are 3.30 each.
Old Nov 9, 2012 | 08:57 AM
  #2505
Robert91RS's Avatar
Shoot, the 88941745 list for $9 in the states lol.
Old Dec 5, 2012 | 09:32 AM
  #2506
rush7's Avatar
Could you get P/N for the following 2000 Silverado 2500 4WD w/ LQ4?
Water pump gaskets?
Timing Cover Front Seal?
Crank bolt?
Heater Core?
Thanks!
Old Dec 5, 2012 | 09:58 AM
  #2507
Robert91RS's Avatar
Water pump gaskets? 12630223 x2
Timing Cover Front Seal? 12585673
Crank bolt? 12557840
Heater Core? 52473322
Thanks!
There you go sir
Old Dec 5, 2012 | 01:48 PM
  #2508
rush7's Avatar
There you go sir
Much appreciated, Robert, Thank you!
Old Dec 20, 2012 | 07:45 PM
  #2509
therock's Avatar
Hi, I have a 2005 Silverado 1500 Z71 4X4 with Drum rear brakes.
Can I get the P/N of the bleed screws for the front calipers and the rear drum wheel cylinders?
Any Size & Thread Spec info would be great also.
Thanks
Old Dec 20, 2012 | 08:45 PM
  #2510
Robert91RS's Avatar
I should be able to help you with that in the morning. Shoot me a pm if you don't hear back by about 9 or 10am, I've been bouncing around lately with all the new GM info coming out.
