Gm Part #anyone?
Old Aug 2, 2009 | 06:33 PM
  #2341
beastmode's Avatar
Import Moderator
Looking for P/N for driver and passenger side black painted mirror caps for 99-06, just want to replace the chrome ones I have now.
Paint code is 41U
TIA
Old Aug 6, 2009 | 10:25 AM
  #2342
whitegmc2003's Avatar
Looking for P/N for painted white driver, passenger and tailgate handles to work on a 2003 Gmc sierra.
thank you
Old Aug 7, 2009 | 03:40 PM
  #2343
h20son's Avatar
Originally Posted by black06
I'm looking for the side mirror delete caps used on the 3500 chassis cabs with the door mounted mirrors like these.....
I need the drivers and passenger sides
VIN from ebay 1GBJC34U64E229905
Originally Posted by h20son
15703457 - left
15703458 - right
Paint code is 41U
TIA
black isn't available, only silver, red, and chrome
thank you
sorry man, nothing available anymore, I can, however, find you some numbers for stuff you can have painted, but depending on cost, you'd be better off calling a junkyard
Old Aug 10, 2009 | 02:58 AM
  #2344
hawaiianstyle's Avatar
Default Ambient HeadLight sensor
Hey Chevracer or BigRed, I searched and read all the threads or post about disabling the AHS and then I tried to do this mod to a 2007 GMC Vortex Max Classic, but it turns out that all the connectors at the BCM are white and there is no purple connecter at the BCM. I want to add my 10k resistor to the wires so my AHS will be disabled. I was wondering if you can get schematics for this or the wire numbers for the AHS? With pictures if thats possible.
Old Aug 20, 2009 | 09:38 AM
  #2345
midnight_bowtie's Avatar
Default Mirror temp/compass Sensor
Can I get the pn for the temp sensor that goes behind the grill for the mirror as well as the pn for the plastic push-in clip for said sensor.
edit: found the pn 15047946 on google. Can anyone pls verify that its the correct one.
Thanks,
Old Aug 21, 2009 | 10:20 AM
  #2346
Rays B4U's Avatar
When you've got a minute I could use the part number for the panel that holds the drivers side window/ mirror/ lock switches. VIN:
Thanks!
Old Aug 21, 2009 | 02:22 PM
  #2347
Whippled 496's Avatar
Looking for steering wheel clock spring part #. Wheel has redundant radio controls RPO code UK3
VIN # 1GCHK29G93E259036
Old Aug 25, 2009 | 10:09 AM
  #2348
fastnblu's Avatar
Any chance u could find me P/N for a smooth wraparound tailgate cap?
I need to replace the big 04 style so it'll play nice w/. a tonneau. I have no idea what yr they're from, only that they were on the 99-07.
Also, Front Bumper Cap from a 06 Silvy. TIA
I don't think u need my VIN, since they came on different yr. Silverados.
Old Aug 31, 2009 | 12:21 PM
  #2349
Nev194's Avatar
I need the P/N for the plastic hand nut that holds down the jack kit cover in a 2006 regular cab silverado. It holds down the cover that runs almost full length from side-to-side behind the seats. The interior is tan if that matters and this cover did not come on the W/T models.
Thanks
Old Sep 11, 2009 | 03:00 PM
  #2350
PathfinderJr's Avatar
passenger rear outside rear door handle for an 03/04 Arrival Blue truck? I'm guessing it has to be a crew cab, SS, or Avalanche truck to have the full four doors.
My passenger door lock cylinder got busted when someone broke into my truck, so instead of spending $75 to replace the cylinder, I'm gonna spend a little more to get color matched handles and eliminate the passenger side keyhole at the same time.
