Gm Part #anyone?
#2343
I'm looking for the side mirror delete caps used on the 3500 chassis cabs with the door mounted mirrors like these.....
I need the drivers and passenger sides
VIN from ebay 1GBJC34U64E229905
sorry man, nothing available anymore, I can, however, find you some numbers for stuff you can have painted, but depending on cost, you'd be better off calling a junkyard
#2344
Hey Chevracer or BigRed, I searched and read all the threads or post about disabling the AHS and then I tried to do this mod to a 2007 GMC Vortex Max Classic, but it turns out that all the connectors at the BCM are white and there is no purple connecter at the BCM. I want to add my 10k resistor to the wires so my AHS will be disabled. I was wondering if you can get schematics for this or the wire numbers for the AHS? With pictures if thats possible.
#2345
Can I get the pn for the temp sensor that goes behind the grill for the mirror as well as the pn for the plastic push-in clip for said sensor.
edit: found the pn 15047946 on google. Can anyone pls verify that its the correct one.
Thanks,
Thanks,
#2347
Looking for steering wheel clock spring part #. Wheel has redundant radio controls RPO code UK3
VIN # 1GCHK29G93E259036
#2348
Any chance u could find me P/N for a smooth wraparound tailgate cap?
I need to replace the big 04 style so it'll play nice w/. a tonneau. I have no idea what yr they're from, only that they were on the 99-07.
Also, Front Bumper Cap from a 06 Silvy. TIA
I don't think u need my VIN, since they came on different yr. Silverados.
#2349
I need the P/N for the plastic hand nut that holds down the jack kit cover in a 2006 regular cab silverado. It holds down the cover that runs almost full length from side-to-side behind the seats. The interior is tan if that matters and this cover did not come on the W/T models.
Thanks
Thanks
#2350
passenger rear outside rear door handle for an 03/04 Arrival Blue truck? I'm guessing it has to be a crew cab, SS, or Avalanche truck to have the full four doors.
My passenger door lock cylinder got busted when someone broke into my truck, so instead of spending $75 to replace the cylinder, I'm gonna spend a little more to get color matched handles and eliminate the passenger side keyhole at the same time.
