Gm Part #anyone?
Old Dec 26, 2007 | 03:41 PM
  #1621
CHEVRACER83's Avatar
Originally Posted by xXxSilveradoxXx
I'm looking for the part number for a couple of crossmembers on the chassis. I'm not sure if you can order these from the factory or not but I need some none the less. I'm looking for the two crossmembers that are behind the rear axel that hold the gas tank. The vehical is a two door Tahoe. This is what they look like. (these specific crossmembers are on a OBS Suburban, the 2-Door Tahoes that I need may appear different)
The crossmember closest to the axel.
The crossmember closest to the rear bumper.
Also, this should be easier, I need the hollow stud that the oil filter screws onto on a 1998 C-2500 with a Vortec 454. You can see it missing in this picture.
FITTING 3853870
THE CROSSMEMBERS ARE SHOWING ONLY AVAILABLE AS THE FULL FRAME... THEY USED TO BE AVAILABLE INDIVIDUALLY.. THEY DISCONTINUED THEM INDIVIDUALLY...
Old Dec 26, 2007 | 04:04 PM
  #1622
Originally Posted by cmatt
Looking for a couple of things:
1. Cap that goes with radiator overflow tank on a 2003 Envoy XL 6.2L.
VIN 1GKES16S536184890
2. Escalade headlight control switch from 2003 and up.
3. Smooth paintable mirror caps for GMC Sierra Classic.
4. Is the serpentine belt (12576451) that fits a 5.3L with 145A alternator the same for a 160A alternator?
5. Tailgate cap that goes with this VIN 2GTEK13Z971111600.
6. Paintable side molding for a crew cab GMC Sierra Classic.
7. Step shield for Sierra Classic crew cab. Like this for ext. cab (12497356), but for crew cab.
I know it's a lot. Thanks for the help.
1 15060681
2 15194803
3 TELL ME WHAT COLOR YOU NEED... THEY DONT SELL THE CAPS SEPERATE I WOULD HAVE TO GET YOU A KIT ALREADY PAINTED
4 SAME BELT
5 DEPENDS ON WHICH ONE.. IF ITS THE STEP STYLE 15932247 THE SMOOTH COVER 15932261
6 FRONT 88937187 NEED 2 REAR 15118135 NEED 2
7 THEY DIDNT MAKE THE STEP SHIELDS FOR THE CREW CAB CONFIGURATION FOR SOME STUPID REASON... IM SORRY
Old Dec 26, 2007 | 04:06 PM
  #1623
Originally Posted by 67Cowboy
Guys I have a 1976 C30 that I would like to convert to intermitant/pulse type windshield wipers. I believe I need the switch that fits '78-'83 but I don't know if I need to change wire harness or wiper motor. Do you have a listing for the numbers and their differences ?!?
I DONT HAVE A LISTING FOR DIFFERENCES... BUT I DO BELIEVE IT REQUIRES A BEW DASH HARNESS, BECAUSE IT USES A COUPLE EXTRA WIRES FOR THE DIFFERENT PULSE SETTINGS.... NOT TO MENTION THE FRONT CHASSIS HARNESS WHICH HAS THE CONNECTIONS FOR THE PULSE MODULE (CIRCUIT BOARD)
Old Dec 26, 2007 | 04:09 PM
  #1624
Originally Posted by blksilverado
I am looking for the part # for stock ls1 5.7 pistons. I have 12575663, but its not giving me anything. Did they change the part #?
88984245 IS WHAT I CAME UP WITH FOR A 02 CAMARO LS1
Old Dec 26, 2007 | 07:07 PM
  #1625
Derek @ EDO's Avatar
FormerVendor
Originally Posted by CHEVRACER83
SORRY DEREK THEY ONLY COME ON THE SHROUD
Thanks man!
Old Dec 26, 2007 | 07:12 PM
  #1626
joshua022's Avatar
6.0 head gaskets
I just got a set of head gaskets from someone on this website and was wondering if you can look up what the thicknesses are on them?
#12575392
this number was written on a piece od tape on the gasket package I don't know if it is correct or not #12589227
thanks a lot
Old Dec 26, 2007 | 09:44 PM
  #1627
Stoichiometric's Avatar
Part number for standard 99+ 1.7 ratio rocker arms?
Old Dec 26, 2007 | 11:08 PM
  #1628
cmatt's Avatar
1 15060681
2 15194803
4 SAME BELT
Thank you so much!! Here's the info you needed:
3. Greystone metallic, 16U
5. A little confused on this one. What's the difference between the two? I'm looking for the black trim that covers the top edge of the tailgate.
Like this:
I really appreciate the help.
Old Dec 26, 2007 | 11:23 PM
  #1629
blksilverado's Avatar
Thanks chevracer, appreciate the help.
Old Dec 27, 2007 | 01:28 AM
  #1630
Like this:
ok thats the smooth cover one...
