Gm Part #anyone?
#1264
Originally Posted by dmc_racer
What's the part # for the A/C **** and light switch **** out off a 2002 Escalade?
thanks
thanks
9379907 ac **** for escalade...
they only make the headlamp switch as an assembly.... you cant buy the **** seperate
15062684 headlamp switch for escalade
#1265
Originally Posted by Bill Reid
2006 Silverado 5.3 2WD... are the front springs the same part number or are they different for each side?
... the driver side likes to dive more than the passenger side when going over bumps and this started when I removed the Belltech springs and installed McGaughy's 2" drop spindles with original springs... and I didn't label each side when I removed them originally.
Also, I installed the GM service kit, based on the TSB, for the "Chevy Lean"... and it doesn't seem like its enough. Is there another more aggressive fix?
Thanks,
Bill
Thanks,
Bill
they are the same weight spring, but the left and right are different part numbers, so it is possible that it is wound a little different to give it the extra give going over bumps.... but i dont think it is.
#1266
Originally Posted by TurboBerserker
Aight CR83... ya ready?
2004 GMC sierra DMAX SLT --
bose 6-disc head unit
DS power lock switch
the little rubber mat for the "top shelf" in the the center console (the small one between the two 12v powers)
change cup thing (ash tray??) that fits in the center console
rubber mat for the console at yer elbow
Thanks bro
Thanks bro
HEY BRO CAN I PLEASE GET YOUR VIN... THERE ARE ALOT OF TRIM OPTIONS I NEED TO FILTER FOR THIS THING
#1267
Originally Posted by Y2KSierra
I'm looking for the door handles and outside mirror covers (front caps) prepainted in Graystone Metallic for a 2007 Tahoe.
Here is a vin number from a Tahoe with the parts I want:
1GNFK13047J150632
Thank you so much if you can help me out!
Steve
1GNFK13047J150632
Steve
THE HANDLES DONT COME PAINTED... THEY ARE PAINT TO MATCH
FRT LH 15915129
FRT RH 15915130
REAR LH 15915639
REAR RH 15915640
17800741 MIRROR COVER PACKAGE PAINTED IN GRAYSTONE
#1268
Thanks bro
Thanks bro
CHANGE CUP 22611384
HOLDER FOR CHANGE CUP 15168217
ELBOW MAT 15168289
THE REST I NEED THE VIN.
#1269
Originally Posted by Wide Open
Please provide me the part number for a 2003/2004 Silverado/Sierra throttle pedal assembly. The dealer sold me part number 15101848 but it doesn't bolt to the pedal bracket.
Thanks.
Thanks.
BUT COULD ALSO BE 89059124 BUT THATS ONLY WITH POWER ADJUST PEDALS.... SO THE FIRST NUMBER SHOULD BE RIGHT.....
THATS FOR 03.... 04 HAS ABOUT 20-30 OPTIONS... SO LETS HOPE THIS WORKS...
WHAT TAC MODULE ARE YOU RUNNING?
