Gm Part #anyone?
Old Aug 28, 2007 | 08:20 AM
  #1281
Wide Open's Avatar
Originally Posted by CHEVRACER83
WHAT TAC MODULE ARE YOU RUNNING?
Thanks for the number. I am using a 07 L92 throttle body.
Old Aug 28, 2007 | 08:54 AM
  #1282
beastmode's Avatar
Import Moderator
HELL I DONT THINK BEASTMODE HAS EVER ASKED ME FOR A PART NUMBER WITHOUT OFFERING TO BUY ME SOME SORT OF INTOXICATING BEVERAGE..
that is SO not true
Old Aug 28, 2007 | 10:55 AM
  #1283
CHEVRACER83's Avatar
Originally Posted by beastmode
that is SO not true
YEAH THATS RIGHT.... YOU USUALLY DRINK THEM AND OFFER ME THE EMPTY BOTTLES TO RECYCLE
Old Aug 28, 2007 | 10:57 AM
  #1284
I DROPPED YOU A PM EXPLAINING THE TAC SYSTEM.... ITS WHAT TELLS YOUR THROTTLE WHAT TO DO, AND TELLS THE PCM YOUR PEDAL POSITION, AND YOUR THROTTLE POSITION... AMONG MANY OTHER THINGS IT DOES..
I PM'D YOU THE BREAKDOWN OF THE ENTIRE SYSTEM... BUT HERE IT IS AGAIN
Throttle Actuator Control (TAC) System Description
Purpose
The throttle actuator control (TAC) system delivers improved throttle response and greater reliability and eliminates the need for mechanical cable. The TAC system performs the following functions:
• Accelerator pedal position sensing
• Throttle positioning to meet driver and engine demands
• Throttle position sensing
• Internal diagnostics
• Cruise control functions
• Manage TAC electrical power consumption
The TAC system includes the following components:
• The accelerator pedal position (APP) sensors
• The throttle body assembly
• The engine control module (ECM)
Accelerator Pedal Position (APP) Sensor
The accelerator pedal contains 2 individual APP sensors within the assembly. The Accelerator Pedal Position (APP) sensors 1 and 2 are potentiometer type sensors each with 3 circuits:
• A 5-volt reference circuit
• A low reference circuit
• A signal circuit
The APP sensors are used to determine the pedal angle. The engine control module (ECM) provides each APP sensor a 5-volt reference circuit and a low reference circuit. The APP sensors provide the ECM with signal voltage proportional to the pedal movement. The APP sensor 1 signal voltage at rest position is less than 1 volt and increases to above 4 volts as the pedal is actuated. The APP sensor 2 signal voltage at rest position is near 0.5 volt and increases to more than 2 volts as the pedal is actuated.
Throttle Body Assembly
The throttle assembly contains the following components:
• The throttle blade
• The throttle actuator motor
• The throttle position (TP) sensor 1 and 2
The throttle body functions similar to a conventional throttle body with the following exceptions:
• An electric motor opens and closes the throttle valve.
• The throttle blade is spring loaded in both directions and the default position is slightly open.
• There are 2 individual TP sensors within the throttle body assembly.
The TP sensors are used to determine the throttle plate angle. The TP sensors provide the engine control module (ECM) with a signal voltage proportional to throttle plate movement. The TP sensor 1 signal voltage at closed throttle is above 4 volts and decreases as the throttle plate is opened. The TP sensor 2 signal voltage at closed throttle is below 1 volt and increases as the throttle plate is opened.
Engine Control Module
The engine control module (ECM) is the control center for the throttle actuator control (TAC) system. The ECM determines the drivers intent and then calculates the appropriate throttle response. The ECM achieves throttle positioning by providing a pulse width modulated voltage to the TAC motor.
Modes of Operation
Normal Mode
During the operation of the throttle actuator control (TAC) system, several modes or functions are considered normal. The following modes may be entered during normal operation:
• Minimum pedal value--At key-up the engine control module (ECM) updates the learned minimum pedal value.
• Minimum throttle position (TP) values--At key-up the ECM updates the learned minimum TP value. In order to learn the minimum TP value, the throttle blade is moved to the closed position.
• Ice break mode--If the throttle is not able to reach a predetermined minimum throttle position, the ice break mode is entered. During the ice break mode, the ECM commands the maximum pulse width several times to the throttle actuator motor in the closing direction.
• Battery saver mode--After a predetermined time without engine RPM, the ECM commands the battery saver mode. During the battery saver mode, the TAC module removes the voltage from the motor control circuits, which removes the current draw used to maintain the idle position and allows the throttle to return to the spring loaded default position.
Reduced Engine Power Mode
When the ECM detects a condition with the TAC system, the ECM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The ECM will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
• Limited throttle mode--The ECM will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
• Throttle default mode--The ECM will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The ECM will perform the following actions:
- Limit engine speed to idle by positioning the throttle position, or by controlling the fuel and spark if the throttle is turned off.
- Ignore the accelerator pedal input.
• Engine shutdown mode--The ECM will disable fuel and de-energize the throttle actuator.
Old Aug 29, 2007 | 07:29 AM
  #1285
TurboBerserker's Avatar
I AM A MOTHERF*CKER
10357886 RADIO
15194078 TOP SHELF MAT BETWEEN RECEPTACLES
15883322 DRIVER SIDE MASTER SWITCH
Thank you sir! You've just saved me a major headache (new area, the parts guys so far are all ******** lol -- one even said "Do you know how long it will take me to look that up??" to which I said "No, but I can tell you how long it SHOULD take you..." )
Old Aug 29, 2007 | 07:33 AM
  #1286
I AM A MOTHERF*CKER
Originally Posted by TurboBerserker
Any luck on these?
change cup thing (ash tray??) that fits in the center console
rubber mat for the console at yer elbow
I'm so good with the descriptions I know lol
Thanks for looking man. Hey -- you should do a little paypal account and post a link for donations to your liquid lubrication fund. A guy on the diesel site I go to does VIN checks and has a similar thing in his sig -- let's people donate to the cause when feeling appreciative!
Old Aug 29, 2007 | 07:38 AM
  #1287
Superado's Avatar
11 Second Truck Club
when you just can't stand looking at it's worn out and cracked finish any longer...can you purchase a replacement, fold-down arm rest for the driver's seat in the appropriate color?
just in case you need it...
1GCEC19TOYZ327795
thanks!
Old Aug 29, 2007 | 11:12 AM
  #1288
CHANGE CUP 22611384
HOLDER FOR CHANGE CUP 15168217
ELBOW MAT 15168289
THE REST I NEED THE VIN.
here ya go i posted it back a couple pages.... those i didnt need your vin for
Old Aug 29, 2007 | 11:24 AM
  #1289
1GCEC19TOYZ327795
thanks!
DOES YOURS HAVE A FULL VENTER CONSOLE?? OR IS YOURS LIKE A FOLD DOWN MIDDLE SEAT??
YOURS SHOWS A FULL CONSOLE, IF NOT RECHECK YOUR VIN AND REPOST IT...
IF YOURS HAS A FULL CENTER CONSOLE THEN IT WILL BE 12475013
Old Aug 29, 2007 | 11:27 AM
  #1290
THATS WHATS FUNNY IT TOOK A FEW MINUTES TO DO IT.... MOST OF THEM ARE A) TOO LAZY.... B) TOTALLY INCOMPETENT
