Gm Part #anyone?
Old Oct 9, 2006 | 10:17 PM
CHEVRACER83's Avatar
Talking Gm Part #anyone?
ok guys me and bigredexpress have offered up our services since both of us work at GM... all we ask is if the mods can make this a sticky so that people will know to ask...
also please have your vin code, or vin code for the vehicle you need parts for if possible.
now if you are looking for parts for a different year it cn still be found... it will just make finding stock parts for "your" vehicle easier for us to find.
Old Oct 9, 2006 | 11:45 PM
negativeswitches's Avatar
i need part numbers for the 5 speed clutch pedal assembley
from a 99/00 new bodystyle silverado 4.8L
thanks!!!
-Erik
Old Oct 9, 2006 | 11:49 PM
bigredexpress99's Avatar
Parts list so far -
15713209 - this is a little support bracket for the pedal assembly
15027983 - this is the pedal assembly
GTO 6.0 emblem - 92162158
LS6 intake manifold w/o EGR - 88894339
97 Corvette fuel rail - 12556705
97 Corvette fuel regulator - 12554677
The Clips that hold the injectors to the vette fuel rail - 12554679
Clip that holds the fuel regulator to the vette fuel rail. - 24500246
VICTORY RED DOOR HANDLES - paint code 74U
15015969 - LH
15015970 - RH
both with key holes.
05+ efans
89023365 - Shroud Kit
89023367 - Lh Fan Blade
89023366 - Rh Fan Blade
89023368 - Motor (2 Needed)
89023369 - Motor Clips (2 Needed)
88987983 - conn. for motors
l92 block - 12584727
starter for a 01 suburban 6.0L 4l80e 4x4 - 89017412
steering wheel switches
01999442 - program and source buttons
21997738 - trip/fuel buttons
21997739 - personaliztion
01999443 - seek/volume
trans temp sender for a T56 - 12458118
LS6 intake manifold bolts - 12552344
escalade platinum a/c vent assemblies -
far left outlet - 15784733
center - 10393267
right 2 outlets - 15102493
2006 GMC painted front bumper cap - 12477935
06 GMC front lower valance w/fog lamps - 12335963
99+ tailgate handle bezel - 19150859
bolts for GEN III valve covers - 12577215 x8 needed for an engine
black lower valance (2" strip or so) added in 05 - 10386199 - 2wd
10386198 - 4wd
Remanufactured GM Gen III crate engines
12491851 - 4.8 LR4
12491854 - 5.3 LM7/L59
12491357 - 6.0 LQ4
12491860 - 6.0 LQ9
Silver birch SS grille shell (03-05 SS)- 15138277
chrome bumper (03+ chevy) - 19150310
smooth bumpercap (03+ chevy) - 89025820
pass side fender (03+ Chevy) - 88944419
4.10 for the 8.5/8.6 rear - 12479056
3.08 for the 8.5/8.6 rear - 26038848
8.1 ltr injector - 12574927
l92 complete engine - 12603910
(these are for an 02 5.3, but I assume most are the same)
timing cover gskt - 12574294
H20 pump gskts - 12588372
crank seal - 12585673
balancer bolt - 12557840
valve cover gskt - 12560696 x2
LS7 lifter (Kit of 16)- 12499225
03-07 bostie grill emblem - 12335700
Black painted tailgate handle (SS basically........)
handle - 15188001
bezel - 15187998
Mirrors (fully loaded)
15198009 & 15198010 (LH and RH obviously. With power, heat, turn signal, dimming, puddle light) Its the DL3 option.
Front 2" air dam for 03+ GMC's - 15224192
All LQ4 and LQ9 head gaskets - 12589227 x2
Driveshaft ujoint straps and bolts - half ton tahoe -
07846740 - straps. qty 2 needed.
15734903 - bolts. qty 4 needed.
4L60E tranny drain plug - 24213991
Painted door handles in STORM GRAY METALLIC -
15015959 - LH handle
15015960 - RH handle
Old Oct 9, 2006 | 11:53 PM
moregrip's Avatar
what a rush!
there ya go, and thanks for the service to our members
Old Oct 10, 2006 | 12:44 AM
Thanks a bunch...now lets get this started....
Old Oct 10, 2006 | 02:51 AM
thanks damon.....
no problem between me and bigred....we not only know the part numbers.... but we also know alot of tips and tricks to get things done quicker and better.... we can also help with diagnosis.... so please any questions ask or pm one of us, and we will do what we can
please rememeber we are human though, we go home just like you do. as for me if you need a part i can look it while im at work which i am always on here.... from 9:00 a.m. pst through 6:00 p.m. pst.
please understand when you post a question, or request we will get to it as soon as possible
Old Oct 10, 2006 | 07:57 AM
15713209 - this is a little support bracket for the pedal assembly ~$6.51
15027983 - this is the pedal assembly ~$65 list
Both seem pretty readily available.
Old Oct 10, 2006 | 09:33 AM
UH OH. Just got our catalog updates at work today.......catalog listings for the new GMT900 pickups, not just the 'hoes anymore!!! my god are the fuel pump assembly's cheap......
Old Oct 10, 2006 | 10:10 AM
BlownChevy's Avatar
blownerator
25 Year Member
not bad, I found them for 6.00, and 58.00
Old Oct 10, 2006 | 12:05 PM
99/5.3w/hips's Avatar
Okay a question for you GM guys then. Can 5.3 dished pistons be swapped for 4.8 flat tops pistons easily? is it a basic plug and play thing? They have the same bore size so they should swap right over right? Im asking because the idea has been tossed around by a few board members before and I am wondering if it is really possible and if it is then where can I get some 4.8 pistons and rings.
