getting rid of air in rad
Old Jul 7, 2010 | 07:42 PM
gary pierce's Avatar
Default getting rid of air in rad
What is the best way to get rid of an air pocket in a 5.3 cooling system?
Old Jul 7, 2010 | 08:06 PM
JFOLM's Avatar
Lift the front end up
Old Jul 7, 2010 | 08:19 PM
WorkTruc's Avatar
undo top rad hose from radiator and fill as it is your highest point and air will bleed out
Old Jul 7, 2010 | 09:12 PM
fastnblu's Avatar
Purge it.
Old Jul 7, 2010 | 09:16 PM
budhayes3's Avatar
PT's Slowest Truck
I grab the upper hose and squeeze while pulling it downward, and hold it there as the air will actually "bubble" into the reservoir...you can feel it bubble through the hose actually. I keep repeating this process until the bubbling stops. Usually, after each time that I release the hose, you will see the level in the reservoir drop as the coolant sucks in. I've changed the coolant in my truck numerous times (maintenance, cam swap, e-fan and radiator swap, etc.), and have never had an air pocket.
Old Jul 7, 2010 | 09:18 PM
fastnblu's Avatar
Like that.
Old Jul 7, 2010 | 09:20 PM
Mangled03gmc's Avatar
Baltimore Whore
Winner Winner
Old Jul 9, 2010 | 09:06 PM
Thanks for the advice. I just installed an electric fan and radiator.
Gary
Old Jul 9, 2010 | 09:53 PM
SnakeOiler's Avatar
  1. Fill the system through the surge tank opening.
  2. Pre-mix a 50 to 60 percent solution of DEX-COOL® and clean, drinkable water.
  3. Slowly add the pre-mixed solution to the surge tank until the level is slightly above the surge tank split line.
  4. Start the engine.
  5. Idle the engine for 1 minute.
  6. Loosely install the surge tank cap. Do not allow the system to build up pressure.
  7. Cycle the engine from idle to 3000 RPM in 30 second intervals until the engine coolant reaches 99°C (210°F) and the thermostat opens.
  8. Shut off the engine.
  9. Refer to step 2 in order to remove the surge tank cap.
  10. Start the engine.
  11. Idle the engine for 1 minute. Fill the surge tank to 1/2 inch above the COLD FULL mark on the surge tank.
  12. Install the radiator surge tank cap.
  13. Cycle the RPM. Idle the engine to 3000 in 30 second intervals until the engine coolant reaches 99°C (210°F).
  14. Shut off the engine.
  15. Top off the coolant, as necessary, to 1/2 inch above FULL COLD mark on the surge tank.
  16. Rinse away any excess coolant from the engine and the compartment.
  17. Inspect the concentration of the coolant.
Old Jul 11, 2010 | 02:44 PM
Got all the air out, but I used prestone antifreeze for all makes. Should I change it to dex cool?
