gas tank problem
Old Feb 5, 2007 | 11:29 AM
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by 04BlackSilverado
As soon as I saw the title I knew what your problem was.....
Replace your Fuel tank vent solenoid part# 15138620
Very ease to replace, rear passenger side of the gas tank, about $75-90
I found out the hard way https://www.performancetrucks.net/fo...d.php?t=368161
HAHA I read this thread and was like, I hope 04Black.. replies. Cool.
Old Feb 5, 2007 | 03:25 PM
04BlackSilverado's Avatar
Yeah, as soon as I saw the title....
Old Feb 5, 2007 | 04:06 PM
TarheelZ's Avatar
Yep, me too.
Old Feb 5, 2007 | 04:54 PM
TG02Z71's Avatar
Originally Posted by txredxj
let me tell you it is defanetly a blockage. i have to to barely crack the handle to fill it up and then it will still click off and then i have to wait for the fuel in the filler hose to go down.
This IS exactly the way my wife's car acted. You couldn't even crack the handle more than just a trickle and it would pop the auto-shut of on the pump.
I pulled off the fill tube, hoses that went to the evap canister, the top of the gas tank where the fill tube went in. Nothing was clogged broken or blocked. I even put it all back together with a couple rubber gas line hoses to the evap canister thinking it was possibly the steel vent lines that went to the evap canister and it still didn't work. It turned out to be some mechanical valve that was part of the evap canister. This thing vents fumes out of your fill tube so they don't go to atmosphere, EPA crap I guess. If this valve in the evap system does not function properly it acts as if your tank has been topped off and won't let fuel go down the fill tube. There is a small flapper valve in the fill tubes of some of these systems that actually closes when this system malfunctions.
Mind you I have never ripped apart the system on one of these trucks but the EPA mandates that they all have a similar system.
Just don't want to see you go down the wrong road here.
Good luck!
Old Feb 5, 2007 | 08:49 PM
Exact problem with mine. Did you read the thread that I had?
Old Feb 6, 2007 | 01:47 PM
txredxj's Avatar
no i didnt what do i search under?
Old Feb 6, 2007 | 06:57 PM
The link is in post #6
Old Feb 10, 2007 | 12:22 AM
txredxj's Avatar
well i replaced it and it still sticks a little but not near what it was.and my emissions light is still on
Old Feb 10, 2007 | 10:45 AM
DrX's Avatar
DrX
One way to check if it is the EVAP vent solenoid is to disconnect the line from the solenoid and see if it is easier to fill.
It was my turn last week. Had my truck into the dealer complaining of this same issue among other annoyances. DTC for the vent solenoid(P0446) was set at the time. It has been setting intermittently. They just handed me a TSB for a problem with a certain design of fill nozzle and told me to try a different gas station. Said the solenoid tested OK but the SES light was still on when I picked up the vehicle???? Said they don't usually stick intermittently.
But then the service writer also tried to talk me into a fuel filter service on my 04! So what do they know.
Old Feb 10, 2007 | 11:02 AM
DrX's Avatar
DrX
MIL should go out after 3 consecutive cycles if the fault is no longer present unless you go in and clear it yourself. Also make sure the line to the vent solenoid is not pinched or kinked. Particularly if your tank has been dropped.
