FYI Cheap Valley cover for Gen 4 DOD Delete
Old Jan 23, 2012 | 12:45 PM
getnit1's Avatar
Default FYI Cheap Valley cover for Gen 4 DOD Delete
GM part # 12598832 is the Valley cover that is from the early non AFM 6.2 in the Denali truck it does not have the crankcase vent on the front that has to be plugged to use on the NNBS trucks and comes with the gasket to block off all the AFM oil ports and the bolts. GM list is $42.78 for this part. I kept seeing everyone advertising the LS2 for use GM list is $141.53 and you have to block the vent tube off.
Old Jan 23, 2012 | 07:34 PM
Coban's Avatar
Good find. From what I understand, the PCV system on the bottom of the LS2/LS3 valley cover is better. You just have to plumb it up to the intake.
Old Jan 24, 2012 | 06:12 AM
Tootall's Avatar
the valley cover from a 4.8 also works . . . it's with out the PCV system
Old Jan 24, 2012 | 05:49 PM
Noah Burns's Avatar
will an LS6 valley cover not work in this situation?
Old Jan 25, 2012 | 09:23 AM
Robert91RS's Avatar
No. The LS6 is a Gen3 motor with the knock sensors in the valley. The LS3 or LS7 should have a comperable pcv system to the LS6 though as Coban pointed out. You just plug the valve cover nipple and run the hose from the intake to the valley cover.
Old Jan 25, 2012 | 10:14 AM
Ferocity02's Avatar
I've been seeing this everywhere... what is "DOD"?
Old Jan 25, 2012 | 10:29 AM
Preston129's Avatar
Displacement on Demand. Although it's now referred to as Active Fuel Management (AFM). It's the system that switches the engine from 8 to 4 cylinders.
Old Jan 25, 2012 | 11:40 AM
Ferocity02's Avatar
Ah thanks, and why are people wanting to remove it?
Old Jan 25, 2012 | 11:56 AM
Robert91RS's Avatar
AFM lifters don't like high lift or fast ramp rates.
Old Jan 26, 2012 | 06:55 PM
sand man's Avatar
get the same year 4.8 vally cover , i paid 120 for my ls2 im pissed the 4.8 was for ~40 or less
