Funny rattling noise
Old Jan 10, 2005 | 10:22 AM
Big Mike's Avatar
Default Funny rattling noise
When I'm on the highway doing over 50 mph, there seems to be a rattling noise which is coming from the passenger cowl area. It almost sounds like the windshield wiper is moving around, but its not. Anyone else experience this noise?
Old Jan 10, 2005 | 10:31 AM
greentahoe's Avatar
I have that one and a bunch of other weird noises. My rattling is probably coming from the screw driver bit and extension that I dropped in there and never found.
Old Jan 10, 2005 | 04:07 PM
XLR8NSS's Avatar
Adkoonerstrator
Have someone push on the glovebox door while your driving to see if that's it. My Dads D-max rattles the hell outta the glovebox mainly at idle but, that the only thing close to what your talking about I've ever heard rattle.
Old Jan 11, 2005 | 07:20 PM
ap2002's Avatar
I Dont Know If This Helps, But I Know Some Friends That Used To Have The Same Problem, They Took Off Their Bugshield And The Noise Went Away???? I Guess The Way Some Bugshields And Designed The Air Hits Right Inbetween The Windshield And The Plastic And Makes It Sound Like That???(that Is What They Said?). My Aunt Had The Same Problem On Her 04 Ford And I Told Her About It And Sure Enough That Was The Problem..... I Wouldn't Know Cause I Dont Have A Bugshield????
Old Jan 11, 2005 | 08:12 PM
KeukaZ71's Avatar
ya, my bugflector and window shades from AVS make alot of noise. i just turn up my subs and amp
i also have sound that comes from the glove box and it is a rattling sound like rocks rolling around. but this is at slow speeds. there is air i think in my coolant lines
Old Jan 11, 2005 | 08:24 PM
one03sierra's Avatar
Formerly one92rs
Talking
it is the plastic piece surrounding the antenna. i put a screw in mine that had a bigger head on it and tightened it down some more.
Old Jan 11, 2005 | 08:36 PM
XLR8NSS's Avatar
Adkoonerstrator
Yep, the coolant lines with air in them make noise also. There was some talk on how to remedy this a long time ago on here. Basically just a technique to bleed the system.
I didn't think about the bug shield and antenna thing but, those are definately things that make noise.
Old Jan 11, 2005 | 08:44 PM
chevymec's Avatar
Does it possible sound like rocks hitting the windshield?
Old Jan 12, 2005 | 08:42 AM
Have a bug shield ?
There are 2 things making noise
There are rubber pieces that cover the hood hinges - at speeds over 50 - they will flop and hit the bottom of the hood - make noise - silicone them in place to the hinge
Also the windshield mouldings on either side - flop against the glass - will make a popping noise
remove the mouldings - apply double sided tape to the moulding - reinstall the moulding - and press the moulding to the glass - tape it in place for couple hours.
There are TSB's on both items above.
Drove me crazy for 6 months - til I fixed them -
Old Jan 12, 2005 | 09:16 AM
Big Mike's Avatar
YES!!!!!!!!!!!!!!!!!!!!!!!!!
And I do have a bug shield.
