fuel pump replacement method...
Old Sep 25, 2007 | 06:04 PM
phasemaster1's Avatar
Default fuel pump replacement method...
Just need to know if removing the bed is easier or dropping the tank on empty? Also I have an 2003 did some come returnless? Im pretty sure my has a return just read some were and others wernt for 2003 using the search. Thanks
Old Sep 25, 2007 | 09:53 PM
nonnieselman's Avatar
Pull the bed... its alot easier.. and you can sit on your cross member while your workin on it...
Ive done it twice... me and my buddy picked my bed up and set it behind the truck.
Old Sep 25, 2007 | 10:11 PM
user 108208932024's Avatar
Banned
Pull the bed.
Old Sep 28, 2007 | 09:25 PM
negativeswitches's Avatar
chock another tally for pulling the bed
it only take me and 1 other guy to pull my longbed
removing the tailgate helps the weight issue some
Old Oct 2, 2007 | 10:05 PM
MilDot's Avatar
I drop the tank. but I'm use to it from doing the camaro's so many times... plus I usually don't have any help.
If you do drop the tank, make sure its super low on gas, too much weight.
Old Oct 2, 2007 | 10:07 PM
lowoh8's Avatar
unbolt the bed and tilt it on a jack stand, doesn't even need to come off the truck.
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
