fuel pump options
so its walbro, oem, or nothing? i saw that granatelli(sp) has a pump for ls1-ls6, it looks like holley may have one. i dont know,will one labeled as working for an ls1 work, or are the pumps different?
That is true. Most of the performance electric fuel pumps are re-boxed Walbro's. I have had my pump in for over a year now with no problems. No bleed down issues like Henry mentioned although I was warned that that might happen. I would recommend changing the rest of the fuel pump module if you have an earlier model NBS. There have been some issues with the fuel level sending units and I believe a bulletin on the wiring plug.
I think the problem that people were having with the walbro pumps was the hose inside of the tank. A friend of mine used a non submersive fuel hose and the gas ate it up and it burst inside of the tank. Make sure to use hose rated for fuel inside and out.
