fuel pressure regulator and idle?
Old Aug 10, 2008 | 09:11 AM
phasemaster1's Avatar
Default fuel pressure regulator and idle?
Its been going on for a while now and dont know what it could be. At idle target idle speed is met, sometimes at a stop light or just parked my idle increases Id say 150-200rpm. sometimes I rev it and it goes back to normal sometimes just stays. Now I have a fuel pressure gauge and at idle I get 50psi and normal cruise. When my idle problem begins pressure is at 59psi,this is even at a dead stop. Now my question is can the fuel pressure regulator going bad cause this?
Thanks
Jaime
Old Aug 10, 2008 | 01:00 PM
hog's Avatar
hog
A fuel pressure regulator that is vaccuum referenced (VRFPR) the fuel pressure will be lower when there is high manifold vacuum, like when idling and cruising. When revving or when at WOT, the fuel pressure will rise as manifold vacuum decreases.
Sounds like your FPR is working fine. Try unplugguing the vacuum hose, the fuel pressure should rise from low 50's up to 60psi.
peace
Hog
Old Aug 10, 2008 | 04:39 PM
peace
Hog
Well when I do that it does raise the fuel pressure, but what would cause a vacume loss at idle ? Ive sprayed throttle body cleaner to see if I have a manifold leak and nothing. What would the cause the Idle to raise while at park or drive at a stop? I am loosing vacume I can see it when my fuel pressure is at 60psi and at a dead stop.Cna the FPR act up? If not the quest will continue. Thanks
Jaime
Old Nov 9, 2008 | 12:47 AM
20002wdchevy's Avatar
14 Second Truck Club
Bump. I'm having a similar problem. Spec at idle for my 00' is 55-62psi btw
Old Nov 12, 2008 | 09:29 PM
hog's Avatar
hog
Yeah, having the fuel pressure at 59psi at idle is weird, it hsould be closer to 50psi.
Maybe your regulator is on the way out.
peace
Hog
Old Nov 12, 2008 | 09:40 PM
https://www.performancetrucks.net/fo...d.php?t=425574
Mossyoakglock
Aug 28, 2015 12:49 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
