fuel pressure problems...
Old 01-17-2011, 08:36 PM
20chevy01's Avatar
Default fuel pressure problems...
to start what should the 5.3 fuel pressure be?? i changed the fuel pump this past weekend, and has a new fuel filter. with that it will start and idle fine, when i go to accelerate it bogs down all the way, my pressure reads 40 at an idle and drops 5 to 10 under a steady acceleration.. i am strongly leaning to the fuel pressure regulator is bad, any thought???
Old 01-17-2011, 09:23 PM
I have a gauge for that
Atomic's Avatar
im guessing its a return-style, in that case it should be 50 at idle and 58 at full throttle. Sounds more like your pump is going out. How many miles on it? The stock fuel pumps usually go around 100k
Old 01-17-2011, 09:44 PM
Destroyer of Transmissions
1SlowHoe's Avatar
He said he replaced the pump...I assume with a new pump?
Was it doing this before and thats what promted the pump replacement?
Old 01-17-2011, 09:47 PM
charcoal03silvy's Avatar
me and my dad both have almost 120K on our trucks and haven't replaced a single OEM thing
Old 01-17-2011, 09:50 PM
Atomic's Avatar
Oops, I read filter instead of pump. Yea change the filter and reg, both are pretty cheap and easy.
I said usually go around 100k
Old 01-17-2011, 10:15 PM
20chevy01's Avatar
i replaced the pump with a new fuel pump this weekend. the filter was changed about 5 weeks ago cuz thats what i was thinking it was. and yea it was acting up before the pump and filter.. now both are brand new and its still acting up. im stumped and i am almost completely sure its got to be the reg. but the pressure is staying right around 40 psi and drops at full throtle.
but if i gradually build up to i can get the rpms up all the way, but very slowly
Old 01-17-2011, 10:17 PM
Atomic's Avatar
I wouldnt recommend doing that. Chances are you are running very lean in the process, go ahead and ask me how fun it is going lean at full throttle
Old 01-17-2011, 10:18 PM
1SlowHoe's Avatar
Unless you have a "Z" in your vin (Flex Fuel) then your 40psi is low. I'd replace the FPR and see. Easy and cheap...
Old 01-17-2011, 10:22 PM
1SlowHoe's Avatar
Looks like this ...
Old 01-17-2011, 10:29 PM
Atomic's Avatar
I was going to say this
Quick Reply: fuel pressure problems...
