fuel injector issue.
Old Jan 15, 2008 | 04:29 PM
brobradh77's Avatar
thats odd. You should be able to fire it up with or without a tune so I dunno.The only thing i am wondering if ythe polarity is switched on some if that even possible with the wire connectors.
Old Jan 15, 2008 | 04:39 PM
midnight_bowtie's Avatar
Old Jan 15, 2008 | 04:41 PM
Banned
Polarity Is Positive And Negative Hes Sayin Maybe They Are Backwords Or Sumthing
Old Jan 15, 2008 | 04:47 PM
Banned
I Just Checked And They Are The Same Part# And Everything. And As Stated Above I Dont See Y They Would All Fail Wen They Were In Workin Condition
Old Jan 15, 2008 | 04:55 PM
got u...
Old Jan 15, 2008 | 07:25 PM
brobradh77's Avatar
yes..when i upgraded to 60# ers we had to splice and add new pig tails we had to be careful that all were the same.
Old Jan 16, 2008 | 01:21 PM
BlackPearlZ71's Avatar
I think it's ur baby's sign language saying "I want a 6.0" hahaha!
Old Jan 16, 2008 | 02:36 PM
Zick's Avatar
Only thing I can think of is making sure all the connectors are connected solid. I know those grey plastic retainer clips are a PITA.
You didn't get the connectors mixed up did you?
I know when I swapped out the injectors on my 03' to 31lbs it started up fine without a tune. Although I didn't drive it far before getting my tune adjusted.
Old Jan 16, 2008 | 07:49 PM
bigbadwolf54's Avatar
13 Second Truck Club
how long did the injectors sit before you installed them??? I have seen injectors that were working when pulled be "froze" up when you try to use them after a long storage period. might try soaking the ends in some carb cleaner to free up the pintles, its just normal fuel/combustion deposits that cause them to "freeze up" and not work
Old Jan 16, 2008 | 08:15 PM
ramsey rider's Avatar
does the motor turn over ?and just dont start.or it doesnt even start.maybe you plugged em in upsidedown.idk thats weird they should start right up .i know someone with brand new 1s if you need em lol.seriously though if its turning over i would say the inj need to be cleaned on a machine or soak em and blow through them.good luck .
