Fog Lights not working
Old Dec 17, 2007 | 07:07 AM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default Fog Lights not working
Well couple weeks ago I was trying to fix my power mirror switch and in the process of looking for a broken wire, something shorted out and blue a fuse for my locks and power windows and mirrors and it drained my battery, anyways I recharged the battery and replaced the fuse and everything was working exactly as they were before, except the fog lights?? So I just got around to checking the fuses the other day, and there was only 1 fuse I could find and it was under the hood, and it was still good. so whats the problem?? is there another fuse somewhere? or?
Thanks, Zach
Old Dec 17, 2007 | 09:32 AM
Woah brotha'.....that's a head scratcher. Right off the cuff, the only thing I can think to try is take it back to your dealership and have them Re-Flash the BCM again. It could be that the short caused an overcurrent and it's possible that, it could have spazz'd your BCM, causing it to not recognize that you are Fog Lamp equipped. I've seen stranger ****, but....this one is pretty boggling. Anywho....that's what I'd try first.
Old Dec 17, 2007 | 10:56 AM
thunder550's Avatar
High on diesel fumes
Awhile back my fogs quit working too, and I tracked the problem down to the headlight switch. Replaced that and everything started working again. If you have a buddy that you can swap switches with try that and see if it helps.
Old Dec 17, 2007 | 02:42 PM
Piss Pumps for Sale
Any Idea how much it would cost to reflash it?
By the head light switch you mean the **** where you have your dome light over ride etc?
Old Dec 17, 2007 | 02:44 PM
thunder550's Avatar
Yes, has the headlight switch, dimmer, and dome override.
Old Dec 17, 2007 | 03:20 PM
GTOsRamairSilverado's Avatar
ive seen those headlight switches cause quite a few problems. i know of a couple a people that had to replace theirs including mine
Old Dec 17, 2007 | 05:29 PM
Piss Pumps for Sale
my buddy has a 99 silvy, Ill swap them see if it helps
ARC
57
Feb 21, 2022 10:54 AM
Bluchevypick
Aug 18, 2015 09:11 AM
pupi305
Aug 13, 2015 03:48 PM
Ketis
Jul 23, 2015 12:37 PM
atxlt
Jul 20, 2015 11:06 PM
