Fastest lifted truck???
Old Nov 2, 2010 | 05:23 PM
  #41
Bama2door's Avatar
Originally Posted by Bumpers
also i gotta do alot of susp. modifications before i could have anymore power
Like what?? My goal is to have the fastest gas SAS'd 2dr tahoe
Old Nov 2, 2010 | 10:01 PM
  #42
ShredSled's Avatar
Yeah what susp mods you think you need for more power? I get no axle wrap as I am now... just thinking about a 14bolt and a balanced driveshaft, then maybe going coil up front but thats not needed for power.
Old Nov 2, 2010 | 10:06 PM
  #43
sureshot's Avatar
If you're lifted, most likely you will need pitman/idler arm braces, HD tie rods or tie rod sleeves, and limiting straps for the front. Right now sharpshooter and I are experimenting with spring clamps, or going with caltracs in the back. A 14bolt and balanced driveshaft are good mods as well.
Old Nov 2, 2010 | 10:11 PM
  #44
trever1t's Avatar
2nd fastest 5.3 ECSB
when I first came around here there was a guy who lived in the north bay somewhere making more than the dyno could register with a Cummins IIRC. He had some awesome video...wonder where he went?
I personally witnessed one run 12.1 with big ol tires and nerf bars.
Old Nov 2, 2010 | 10:16 PM
  #45
ShredSled's Avatar
Front end is already decked out, cognito pivot and dual shear kit, but only strapped for max droop travel, not for launch control. I may go to heim steering up front but not sure how thatll survive corrosion.
I don't know about caltracs in my situation, definitely if I was 2wd though. Ive got a bds rideglide leafpack and no blocks.
Oh any recommends for driveshafts? Or tips for having one built? 1350 yoke, or what?
Old Nov 2, 2010 | 10:24 PM
  #46
sureshot's Avatar
I had the cognito tie rods with heim joints on my dmax. It was very high quality stuff, but I always kept everything clean so corrosion wasn't an issue. If you go 14 bolt, then I would go with the 1350 yoke.
Old Nov 2, 2010 | 11:37 PM
  #47
Bumpers's Avatar
I'm putting a 6" lift on my truck and not cranking so I will have a lot better angles in the front for the axles sake and I want my truck a tad bigger. I'm goin with heim steering 1" tie rods and cognito pitman and idler supports along with some limiting straps for 4wd launching..
Right now a 4wd launch in my truck is like riding a mechanical bull lol .. I'm also gunna be getting a new driveshaft because I'm tired of shutting down at 100 and mine vibrates alittle.
Old Nov 2, 2010 | 11:45 PM
  #48
fortplainman's Avatar
garret you gona get rid of the BL when you do the 6 inch or no? ill be looking on gmfs for the thread. should look good regardless. what kit are you thinking of running?
  #49
DV2000NJ's Avatar
13 Second Truck Club
I'd bet the mud tires have a LOT to do with the bucking on launch. When I had the MTZs on my truck, it would hop 3-4 times on launch (almost ended up in a ditch once), but with a tire with a better contact patch (worn-*** Revos), it hooks like a ************ every time.
Old Nov 2, 2010 | 11:54 PM
  #50
Bumpers's Avatar
I've launched mine in 4wd on like 10 different sets of tires and it always gets crazy.. I think part of it is the angles everything is at with being crunk up so much.. When I run it at the track I'm gunna run it in street trim just like it would be if someone wanted to streetrace. I think all the upgrades better angles and all that jazz will make a big difference.. And I gotta figure out what's up with my tcase.
