ext cab back window wind noise--repair.
Old Oct 16, 2004 | 09:34 AM
one03sierra's Avatar
Formerly one92rs
Talking ext cab back window wind noise--repair.
here is what i have done to several ext cab's back windows to get rid of the wind noise. first i popped the window arm loose from the latch assembly>>
you can see it still touching here. i pop mine loose with a phillips head screw driver while opening the window.
then i pull it outward and have someone hold it. i drill a small hole in the base of the latch. then i drill a smaller hole in the frame of the door. enough for a screw to start.then i install a screw in the holes and tighten ever so slightly. it only takes about a 1/4 turn and then you are done.
i hope this helps. i can get some better pics if needed.
i also posted this in the tech section. i put it out here so more would see it. if this thread gets moved or deleted then go to the tech section. good luck.
X_Racing1
21
Mar 30, 2016 02:37 PM
mhorn0817
Mar 6, 2016 08:00 PM
rednekferlife101
32
Jan 8, 2016 10:42 PM
06 4.8
Aug 21, 2015 11:33 PM
Suburban2500
Jul 19, 2015 04:50 PM
