Escalade Cluster help needed
Old Feb 6, 2006 | 07:56 PM
chopperbrent's Avatar
Default Escalade Cluster help needed
Got a 00 ECSB 5.3 that i installed a Escalade cluster into for the sole purpose of having the tranny temp gauge . Got my truck fired up for the first time this winter and drove it for about 15 minutes and the needle didnt even register a temp . Its sitting below the 100º mark on the tranny temp gauge .
Now ive got a B&M tranny cooler on there and its only 35ºF out right now but i would think it should read something right ? Everything else on the cluster works .
I wanted to know if maybee when i put my Yank stall in i might of not connected a harness on the tranny back up or something . Does my truck even have the tranny temp sendor on this truck or do i need to add something else to the tranny to make this gauge work .
If i remeber right when i installed the escalade cluster there was only one main harness that i plugged into the back of it and thats it , did i miss something ?
Well hope you guys can help me out .
thanks
Old Feb 6, 2006 | 08:45 PM
02BlueStepside's Avatar
Nothing else to hook up, just plug in the cluster and it should work. Actually, just this morning I happened to look at mine on the way to work, also around 35 outside, and it wasn't registering anything either. I am sure its working, just to cold to see any movement.
Old Feb 6, 2006 | 09:25 PM
wkdivr's Avatar
Mine doesn't register anything until I'm actually out, driving for about 10 minuites. Takes awhile to heat up that fluid.
Old Feb 6, 2006 | 10:08 PM
GatorFan's Avatar
Got a question for you guys. Is it really that simple for the Escalade cluster (just hook it up and go)? I have a 00 GMC 4.8L SCSB 4X4 and was thinking I would like a Tranny Temp Gauge as well but was hesitant about what was involved.
Thanks for any inputs.
Old Feb 6, 2006 | 10:17 PM
SnakeOiler's Avatar
Yes, it's really that simple. Getting the mileage set is another story.
Old Feb 6, 2006 | 10:46 PM
GatorFan's Avatar
Default Escalade guages
What is up with the mileage? Is there a specific year Escalade I need the guages from in order to be a quick plug-n-play swap over?
Thanks
Old Feb 6, 2006 | 11:01 PM
The mileage has to be programmed into the new gauge. I just installed an Escalade gauge in my 99 silverado and everything works fine.
Old Feb 6, 2006 | 11:09 PM
GatorFan's Avatar
Thanks,
I've seen a few white-faced Escalade guages that look awesome and I think that's what I'm going to get. Did you have the cluster programmed from the place you bought it or took it to somewhere else?
Thanks.
Old Feb 6, 2006 | 11:23 PM
I am still trying to find a place that is fairly cheap.
Old Feb 7, 2006 | 01:26 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I didnt get mine reprogrammed just give the person that purchases your truck the old cluster and they can add that to the mileage on the esc cluster. Its not a big deal to me cause I have WAY too much money in my truck to sell it.
