Engine Lift Bolts?
Old Apr 7, 2007 | 11:11 AM
agreif's Avatar
Default Engine Lift Bolts?
Guys, my 6.0 should be coming this week and I'll need to unload it out of my bed with the engine lift I'm borrowing. I'd like to get the bolts taht I need for the chain before I get it so I can pull it out the same day. Any of you remember what size and length bolts you got for the threads in the block?
Thanks,
Andrew
Old Apr 7, 2007 | 12:02 PM
thunder550's Avatar
High on diesel fumes
I just reused some of the bolts off the motor. I think I used the three short bolts from the a/c compressor bracket and a 4th from somewhere else, maybe p/s pump or EGR or something.
Old Apr 8, 2007 | 01:07 PM
agreif's Avatar
Ok, thanks, and I've been reading about using the rear passenger head and front drivers head to pull it out then? Thos accessory bolts have enough thread to thread into the block enough after going through the chain link (apparently as you've done it). Any idea of the thread size?
5.3Okasai
Mar 9, 2022 01:07 PM
thunder550
Oct 8, 2015 04:53 PM
Kaldar
Jul 27, 2015 06:42 PM
08nali
Jul 23, 2015 11:39 PM
EscaTruck
Jul 20, 2015 11:42 AM
