ECSB rear door leak
Old Mar 16, 2005 | 08:00 AM
MilDot's Avatar
Default ECSB rear door leak
The rear drivers side floorboard is soaked every time it rains. It does it when parked too, so it is not coming from the bottom...anyone got a fix for this?
Old Mar 16, 2005 | 08:32 AM
JRsilverado's Avatar
Have you lubricated or conditioned the weather seals? I use Armorall and it does an ok job at keeping them flexable. In the owners manual, they say to use a GM product (of course). I may give that a try to see if it's any better.
Old Mar 16, 2005 | 09:31 AM
MilDot's Avatar
Yep. I doubt that would be it, it has done it since the truck was new...I use 2001 on all the plastics and wd-40 to clean the door jams.
Old Mar 16, 2005 | 06:09 PM
one03sierra's Avatar
Formerly one92rs
Talking
hey buddy do yourself a favor. check the rear cab brake light. mine qwas leaking and running down the side to the floorboard.
Old Mar 16, 2005 | 08:26 PM
HI85WH1's Avatar
I recall a TSB about rear window leakage... it could be coming from there as well
Old Mar 17, 2005 | 08:49 AM
MilDot's Avatar
thanks guys I'm still looking for it...I removed the rear door panel yesterday and tested it w/ a waterhose. found a trickle where the rear door mechanism is. I adjusted that and no more trickle, but the small raised shelf area under the rear seat is also wet, so I must have another problem.
BTW: I tried to reduce the rear window wind noise by tightening the screw in that mechanism and broke the damn screw...
Corvette454l88
Sep 1, 2016 01:24 AM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
Ketis
Jul 23, 2015 12:37 PM
