Dual walbro question
Old Feb 18, 2010 | 09:58 AM
ONLYA4.8L's Avatar
Default Dual walbro question
I am lookin at goin dual walbros and would like to know how to wire them up..
Old Feb 18, 2010 | 03:43 PM
quicksilverado's Avatar
Are you going F/I? If not, a single will carry further than you can push a stock 5.3.
Old Feb 18, 2010 | 03:45 PM
Mangled03gmc's Avatar
Baltimore Whore
Why do 2. Do 1 big bosch
Old Feb 18, 2010 | 10:57 PM
ONLYA4.8L's Avatar
I'm goin with a remote T66/T4 1.14A/R with 15lbs of boost.. The 2 walbros will be cheaper then a larger pump.
Old Feb 18, 2010 | 11:00 PM
Baltimore Whore
You think?? What about the hobbs switch, all that.. Just curious..
Old Feb 19, 2010 | 12:34 AM
ONLYA4.8L's Avatar
yup I looked at both i saw a bsch 300lph for 200 and 2 walbros for 80 bucks a piece.. What would u Do? If i do the 2 walbros, how do I wire em up?
Old Feb 19, 2010 | 08:11 AM
Hook one up with the stock wiring. The second one can get positive from a hobbs switch. The ground can go anywhere on the frame. Make sure you clean the frame good where you connect the ground wire.
With my t67 rear mount, one walbro took me to 12 psi and 11.37@118mph. What kind of power will the t66 support?
Old Feb 19, 2010 | 10:58 AM
ONLYA4.8L's Avatar
It said it will support 800hp.. I wanna go for 600rwp. The dual in tank work or should I pay a lil extra for the bosch? If I go to the bosch 300lph do I have to change all the lines? I'm tryin to go for what would take the least amount of work and will be more bang for my buck. On a bit of a budget.
Old Feb 19, 2010 | 03:46 PM
The dual setup will work great. that is what I have.
Old Feb 19, 2010 | 09:08 PM
ONLYA4.8L's Avatar
I run the dual walbros to the one stock like right? What's the hobbs switch?
