Driver door lock not working correctly...
So when I lock or unlock the drivers door with the key fob or the on door buttons the driver door lock doesn't unlock or lock completely. If I do it manually on the inside or from the outside with the key, it works fine. Although it does take a little more effort manually than I think it should
The passenger lock seems to work fine.
Do I just need to lube the mechanism inside the door or is something else wrong?
This is on my 1999 gmc Sierra 1500 rcsb 2wd
You can just some lithium grease spray on the latch and moving parts but it may do nothing.
The whole lock actuator may need replacement, it is only 18+ years old at this point.
If I give the actuator (I'm guessing) a minute or 2 before trying to lock it or unlock since it was last used it seems to still work correctly.
Does that pretty much guarantee the actuator will need replacing?
I have the same issue. sometimes my passenger handle won't go back in the bucket after opening the door and it will not allow the door to open
I agree with step 1, clean and lube. If that doesn’t help then replace the door lock actuator. The drivers side is always the first to wear out. I’ve lubed the one on my 2002 suburban once and have not had any further issues...16 years old and 280k miles. The miles don’t accumulate like they used to, but I just can’t get rid of it!
AJII
20
Jul 14, 2014 04:53 PM
way2much_01
Jun 17, 2012 10:08 AM
the duke35
Jul 3, 2009 06:30 PM
Larry
Mar 17, 2002 05:07 PM
