dreaded gas smell
Old Nov 14, 2013 | 11:27 PM
FreshDA9's Avatar
Default dreaded gas smell
I haven't had much time to mess with my truck due to school and work but there is a gas smell around the filler neck. The cap looks fine and I have no evap codes being thrown at all or any hesitation while driving. Also no fuel on the ground.
The truck has the awesome rocker rot. and a few small rust spots on the bed next to the filler door. Anyone have a starting point of what i should look for?
Old Nov 16, 2013 | 10:57 PM
RacinRust's Avatar
Truck info? Test your gas cap with a vacuum test. Some auto parts store have the testers. They look like a coolant system tester. Inspect your rubber filler neck hoses and make sure the clamps are tight. I saw some where on the forum another member had a severely corroded filler neck tube also. But its strange you do not have a CEL. Does your CEL come on when you turn the ignition key on without starting the engine?
Old Nov 17, 2013 | 12:11 AM
FreshDA9's Avatar
Its an 01 Silverado ext cab 4wd. 5.3L 4l60.....
Check engine light is working fine comes on with every key on and i have set the cel a few times with EFILive to remember to turn setting back on.
I will take a look at the filler neck, you can smell it real bad but you figure it would set a small or gross leak cel. I have had an older truck that the fuel pump housing rusted on top, but in this truck its a plastic housing right?
Old Nov 17, 2013 | 11:03 AM
MikeGyver's Avatar
https://www.performancetrucks.net/fo...nction-522150/
no codes, either
Old Nov 17, 2013 | 11:31 AM
FreshDA9's Avatar
Originally Posted by MikeGyver
Thanks for that link Mike... im due to service my truck and ima take a good look around the area. This lovely Ohio winters gives us awsome salt rotting and i bet there might be holes like you had.
Is the tank on these plastic? if not known ill just take a look when i go to service the truck.
thanks guys!
Old Nov 17, 2013 | 03:45 PM
MikeGyver's Avatar
Originally Posted by FreshDA9
...Is the tank on these plastic?...
Yep.
QUOTE= performancetruck.net The message you have entered is too short. Please lengthen your message to at least 5 characters.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
nic351
Sep 24, 2015 09:43 AM
