diagnosis results
Old Oct 29, 2009 | 01:25 AM
slow.8's Avatar
and yes, ill be doing my own work. slowly but surely
Old Oct 29, 2009 | 04:06 AM
viciousknid's Avatar
Where's the Beef?
Maybe it's just hydrating?
Old Oct 29, 2009 | 06:53 AM
Originally Posted by slow.8
i had a misfire on cylider 5, and i have been losing a lot of coolant. the place i took it to said they "found coolant passing by head bolts and into crankcase,would require valve job,recommend replacement engine due to mileage of current engine" which is 174k. ive read about coolant leaks with aftermarket heads, that they put rtv on the bolts and it stopped leaking. i asked the mechanic about this, and he said he wouldnt recommend it, because of the way the bolts need to be torqued down on the head. i dont know about the water in the crankcase, ive passed about 10 gallons through this thing the past couple of months, wouldnt it be full of coolant? the oil is dirty but it doesnt look to me like its been contaminated with water, while the guy says it shouldnt look like it does. he said he removed the valve cover and found a bunch of contaminated oil.as for the misfire he says its water getting into the cylinder. the plugs are dry.it wont hold water but for a few days, now. im wanting to know about the rtv on the bolts, is he right? if that doesnt work, i guess its gonna sit for a while....(yet again) until i can find an engine for it. now i gotta see if i can get my beater running. anyway, comments on putting sealant on the bolts would be appreciated.
thanks
This sort of thing rears it ugly head from time to time with certain GM Casting Heads. There is a GM Tech Bulletin on this very subject. Let me see if I can attach it for you. Maybe this will give you some help.
Old Oct 29, 2009 | 06:54 AM
Ahhhhhh hell.....for some reason the Manage Attachments button is not working! It won't let me send you the bulletin in an attachment.
kainzien
Nov 10, 2023 11:37 AM
Cha_Feel_
Sep 23, 2015 09:06 PM
FormulaZR
Sep 14, 2015 05:23 PM
black00chev
Jul 31, 2015 04:33 PM
BIGD4504
Jul 28, 2015 11:46 AM
