Dexcool in oil
Old Mar 9, 2010 | 10:19 PM
Big Port Jimmy 6's Avatar
Default Dexcool in oil
Does dexcool in oil look like regular old coolant in oil? I drained my 5.3, it seemed to have more oil than it should (nearly 3 pans) and it was slimy and sticky. It was not the tan coffee look of water. I should have took some pics but oily digits and digital cameras do not mix. Jay
Old Mar 9, 2010 | 10:24 PM
00ChevyScott's Avatar
Wearin' da big hat
You filled 3 pans when you changed oil? Something is F'd up for sure.
Old Mar 9, 2010 | 10:28 PM
viciousknid's Avatar
Where's the Beef?
Did you not check the oil when you purchased it? that would have definitely been noticeable on the sticxk
Old Mar 10, 2010 | 07:28 PM
JoeGibbSilverado's Avatar
regardless of color, three pans? as stated above, something isnt right. it sounds like its mixing,
Old Mar 10, 2010 | 07:42 PM
I Know somethings wrong. I just missed the stick. still what does the mix look like? Is it strawberry shake, or more like syrup. Jay
Old Mar 10, 2010 | 07:43 PM
hirdlej's Avatar
Check your radiator, perhaps your oil cooler is cracked........
Old Mar 10, 2010 | 07:48 PM
Its a pull out. I do not have the truck. It also didnt have an oil cooler. Jay
Old Mar 10, 2010 | 08:17 PM
Wearin' da big hat
If it had a bunch of coolant in the oil pan, and it's a pullout motor, I'd be looking for a new motor.
Old Mar 11, 2010 | 01:47 AM
Evil Eric's Avatar
sound like it was pulled out due to a blown head gasket.
Old Mar 11, 2010 | 01:55 AM
00Silv4.8's Avatar
pull the heads and go from there. maybe was overfilled for storage reasons? I am thinking its most definitely head gasket. How do you know the vehicle it came from didnt have a trans cooler in the radiator?
