In desperate need of help. Misfire issue.
You could try running a continuity check on the coil wiring harness back to the PCM connectors. Maybe some thing got pinched or burned.
check your plugs are torqued correctly and not cracked.
try changing your o2 sensor in that bank?
I really appreciate all the help from everyone. I don't post much, but I have been lurking on this site for a long time. Lots of knowledge and great advice to be had here.
Well, still no luck. I tried some new plug wires to no avail. I took the intake manifold and valley cover off to see if I could inspect the cam for worn lobes. The cam looked in great shape. Its as if its mechanically in time but electronically out of time. I'm going to pull the starter today and see if i can inspect the reluctor wheel on the crank. Maybe it slipped? If I don't see anything there I may just throw a new crank sensor in it and see what happens.
I would check your injector fuses and wiring. Make sure all injectors get power and have a good ground. If that's not it get the injectors tested somewhere or swap out or different ones?
Nope I didn’t. I should have read the directions completely before I started. I replaced the oil pan gasket because it was leaking pretty bad. I checked the reluctor wheel while I had the pan off. It looked good and hadn’t slipped. I replaced the crank position sensor also and was able to complete the relearn procedure. Still misses.
Sounds just like the issue I’m currently having. Tried everything I can think of and mine still missing. I’m about to make a harness for the coils by themselves and repin them and try that.
