Denali Problems
Old Aug 18, 2009 | 12:21 PM
BW3's Avatar
BW3
Default Denali Problems
I have a 2006 Denali with a Zex wet 125 kit. I have had the system on for almost a year with no problems at all. It has started to throw a vehicle speed sensor, and TPS code randomly. You can drive along and it will act like you are taking your foot off the gas for a quick second then putting it back on. I can go 500 feet before it goes into “reduced engine power”, or it may go ten miles before it does it. If you turn the truck off and give it thirty seconds then it will start without the “reduced engine power”
I immediately changed the resistor that is in the TPS wire for the Zex system but that didn’t do anything. So then I cut the Zex TPS wire altogether and that didn’t work either. Any thoughts out there?
Cheers
Jon
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
GMCtrk
18
Oct 6, 2015 03:48 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
