Cross drilled rotars
Can't you make your own cross drilled brakes by drilling a few holes in the rotars in a pattern. Wouldn't it help heat diplacement? just a thought because I'm going to have my rotars turned, because after a few times at the track power braking it ,it think I have warped them a bit.
Originally Posted by Slowverado
well then oh mighty one....what is the correct way??? enlighten the rest of us cuz i might do it if i know how
Well Mr. I know everything about trucks, and I like to bust peoples *****...
If you lay out a pattern on the rotor and keep the holes between the cooling veins, and you don’t get aggressive with the drilling. Then you will be able to do it. I would not recommend doing it without a drill press and some sharp bits, and a whole lotta time and patience.
Banned
hmmm, i never said i know everything (but i do) but i have never done anything with brakes and what-not but it might be worth it if it is as effective as buying an expensive set of drilled rotors. didn/'t you tell me at one time you could get us cheap drilled/slotted rotors from somewhere?
Yes I did, and my cheap *** decided to do it myself.
