Crankcase ventilation issue
Old Jun 16, 2019 | 02:54 PM
celicaxx's Avatar
Default Crankcase ventilation issue
So I swapped lifters and cam in my L59, 2004 Suburban. One of the lifters failed and scarred the cam.
Now I have a new issue. This thing smokes like crazy if it sits and idles, but clears up when I drive it above 2k rpms. I changed the intake gaskets, cleaned out the intake (had lots of oil), and also swapped the passenger valve cover with a spare I had.
One thing I noticed is if I pull the driver crankcase vent line that goes from the valve cover to the intake, it has substantial vacuum pulling from the intake. If I pull the line that goes from the passenger valve cover, there is almost no change in idle or vacuum sucking on the intake port (the one just behind the throttle body).
Should I be getting a substantial vacuum draw through that hose? I would imagine so.
Thanks for looking, and yes, I've been searching for this remedy for a few days online.
Old Jun 16, 2019 | 03:57 PM
MikeGyver's Avatar
The fitting that is on the throttle body on my truck is ported internally to the inlet side, or air filter side, of the throttle blade. It's where fresh filtered air goes into the crankcase. What you describe is normal.
Old Jun 16, 2019 | 07:15 PM
celicaxx's Avatar
Where my line goes in is behind the throttlebody; I'll get pics later
stoicho315
Feb 14, 2013 04:21 PM
afterburn84
May 10, 2011 06:53 PM
moregrip
Sep 7, 2007 09:34 PM
moregrip
26
Jun 15, 2007 08:32 PM
