Cost for a Turbo Setup
Old Oct 7, 2011 | 04:35 PM
svtlightning02's Avatar
Default Cost for a Turbo Setup
I got a guy that works with me that has a 03-04 ecsb with a stock 4.8. the truck is completely stock other than exhaust. he has been asking me about a turbo setup for the truck and i have now clue what to tell him. could you guys give me a ball park figure for a turbo setup on a 4.8. include turbo, exhaust, fuel system everything needed for a turn key turbo 4.8 rado.
Old Oct 7, 2011 | 07:18 PM
zeake's Avatar
10gs would get him started. Till something like the rearend or transmission breaks.
Old Oct 7, 2011 | 07:53 PM
stock48's Avatar
9 Second Truck Club
How fast does he want to go? It could be done for less than 10K if he's not trying to set a land speed record and does the labor himself. There is a lot of things people do that are a waste of $ IMO. A basic Intercooled KB T70 kit with 42lb injectors, and a 255 intank, ,converter, shift kit and tune should get a guy eaisly into the 12's until like said above the trans or rear end breaks. 12's should be ok for a little while on the stock trans. You could run the stock muffler with a cutout, or a single 3 or 3.5'' magnaflow hooked to a 4~5' piece of straight pipe off the dp. For a 10 sec truck he's gunna have to spend a bit more. It's the meth kit, head studs, 80E swap, and rear end stuff that kills you.
Old Oct 7, 2011 | 08:29 PM
thunder550's Avatar
High on diesel fumes
I'd say $10k to have a reliable turbo truck. My rule of thumb was always double the expected cost and triple the amount of time it would take to get it done.
Old Oct 7, 2011 | 08:58 PM
zeake's Avatar
Flip stock manifolds and use twins.
Old Oct 7, 2011 | 09:24 PM
Coban's Avatar
With the cost of the new kits constantly dropping. You can get into a reliable kit for $4-5K easy. You will need a new transmission soon after you install though so figure at least 2K for that as well.
10K is way too high.
Turbo's are never turn-key.
You should also tell him to make an account on here because he's going to need a lot of help.
Old Oct 8, 2011 | 07:41 AM
he isnt wanting to break any records. just wants a basic setup something i guess like slowec on here has.
list of parts needed and im sure i left some out
- Turbo kit
- 42lb injectors
- 1 or 2 255lph pumps
- stall converter
- tune
feel free to add anything else needed. slowec said he bought his turbo for $1800
Old Oct 8, 2011 | 12:27 PM
03regcab sierra's Avatar
I have about 7 grand in mine with heads/cam swap built rear end and built 4l80e all the parts in my sig
Old Oct 8, 2011 | 10:43 PM
bluebommer07's Avatar
wondering samething i have been ******* off the 5.3 i have now in my truck because i know if i was to mod it i would want bigger faster and better, so now i have made my mind up. with the above. and i would cut cost in the long run by just building what i want instead of modding current motor then more money for bigger setup.
Old Oct 9, 2011 | 12:15 AM
gavin2005's Avatar
kbracing turbo kit..around 3300 with intercooler..i think that price is right,not sure tho...go ahead and put atleast 60lb injectors in it or you will be upgraded later like i did.you can find them around 300 used..1 walbro 255 will be fine unless he wanting to make over 550rwhp.100 bucks...circle d 3200..400 bucks i think.put a transgo hd2 kit and vette servo in trans and a 40k trans cooler.that should get him started
