Coolant brand
Old Sep 4, 2006 | 10:15 PM
  #21
sroach20's Avatar
sounds expensive, what did that set you back?
Old Sep 4, 2006 | 10:28 PM
  #22
wouldnt your water only vaporize if your temps got about 212*F? but what if you just added a littlebit of coolant? i thought water had a higher specific heat than coolant, coolant just froze at a lower temp (antifreeze)
Old Sep 4, 2006 | 10:44 PM
  #23
Originally Posted by moregrip
NPG+?
NPG-R lower viscosity works well enough to keep my 403 cool at 100+degrees in rush hour traffic with just electric fans.
Old Sep 4, 2006 | 10:58 PM
  #24
sroach20's Avatar
normally you only want to go to about 60/40, anymore than that and it might raise your pressure too much.
Old Sep 5, 2006 | 09:23 AM
  #25
97sicksled's Avatar
i would think that that would work, a little bit of coolant or maybe some water wetter like Goshawk and you should be fine. Your in Texas so i wouldn't think freezing would really be a worry for you.
The Orange crap does gunk up i've personally had this crap gunk up my engine in my work van and i've had it destroy a radiator and damn near the whole cooling system in another truck.
Old Sep 5, 2006 | 09:33 AM
  #26
i think im gona try and drain it somewhere and replace with some water, waterwetter and maybe a little coolant. but who knows when ill actually get around to it
Old Sep 14, 2006 | 08:00 AM
  #27
Beastofa327's Avatar
Here's a chart for everybody! http://www.valvoline.com/zerex/pdf/Z...olantChart.pdf
Old Sep 14, 2006 | 10:59 AM
  #28
mwalls54's Avatar
Need More N2O Mod
Originally Posted by goshawk23
i've seen the orange stuff gel up in a few motors. i say drain it and run water with a touch of coolant. weather it be orange or green. i don't. i run water with water wetter. but you don't have to be like me.
ditto here except i use purple ice. I have been running it like this for a few years.
Old Sep 14, 2006 | 01:26 PM
  #29
bigredexpress99's Avatar
Putting the system under pressure increases the boiling point of the liquid. I think it is about a 1.5 degree increse in boiling point per point above atmospheric pressure. So, figure your at sea level, about 29.9 inches of mercury, the boiling point is 212. Then, put that "16 lb" cap on the system....236 degree boiling point......
Old Sep 14, 2006 | 05:02 PM
  #30
I bought some kind of stuff a month and a half ago that is supposed to be compatible with all engines whether they use green or orange...supposedly with this stuff in my radiator i can run either one with no problems. been running green since then with no problems.
