Components? Come on in....
Old Jul 3, 2003 | 02:46 PM
FILE's Avatar
Default Components? Come on in....
I am going to be running components in my truck(MB Quart PSD 216). I don't know where to place the crossover. In my 01 model, I placed them inside the doors but after a year or so the screws started corroding. Keep in the mind the MB quart crossover are a little bigger than the average size. So where else do you all suggest to put them other than inside the doors?
File
Old Jul 3, 2003 | 02:52 PM
rgvsierra's Avatar
Default Re: Components? Come on in....
sounds like your system is comming along, what amps are you using for the solobarics and mb quarts? how about the headunit?
i'd like to hear your setup once its completed.
Old Jul 3, 2003 | 05:03 PM
RED2K's Avatar
Mine are hidden in my door. My x-overs might be a bit smaller. I run some Boston Pro's for mine. I run them through PPI amps.
Old Jul 3, 2003 | 06:11 PM
FILE's Avatar
I am using an Orion XTR 500.3 for my 10L7 and a Phoenix Gold 300.2 for the Quarts. I wanted to buy another Orion 500.2 fo the mid and highs but they were out of stock locally. So I got the Phonix Gold. It's supose to work real good. as far as the head unit I will running an Alpine CDA 9813.
RGVsierra, I will let you know when it's done so you can listen to it.
File
Old Jul 6, 2003 | 10:15 AM
one03sierra's Avatar
Formerly one92rs
i mounted mine in the center console
Old Jul 6, 2003 | 04:31 PM
FILE's Avatar
I am just gunna put them somewhere behind the rear seat. I am just going to hate running 2 wires instead of one.
File
Old Jul 6, 2003 | 09:03 PM
Hit Man X's Avatar
Hey I run JL XR653's in the front of my truck and my x-overs are mounted (I don't have any pics but I will try to explain):
on the drivers side... near the gas pedal there is a big open space up and to the right. I mounted it there.
on the passanger side... sorta stuffed between the dash and the box where the evap core is. Mine are all secured via a screw to the nearest flat space.
I would not mount your x-overs in the doors. There is too much moisture in there and they can corrode and rust, not good. Just keep some air to them so they can cool off and your seperates will live a long and happy life.
I'd adjust your x-over points on your amp around 80hz @ 24db/oct if they are 6.5" speakers and you have a sub in the mix. If you are lacking a sub I'd drop to 18db/oct or maybe even 12db/oct for a bit more from the mids.
My three ways are: 80-300 midbass, 300-5000 midrange, 5000+ tweets. At least I think those are my midrange points...either way all my stuff is bandpassed and I run 24db/oct points for a steeper drop off for cleaner sound.
Wolftrk99
Oct 2, 2015 08:17 AM
g6t6o
Sep 26, 2015 10:57 AM
97_ek
Sep 23, 2015 09:16 PM
whitelazer
Sep 22, 2015 09:38 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
