Cold Air Intake....
Old Mar 24, 2008 | 12:11 AM
Bismarck's Avatar
Default Cold Air Intake....
Has anyone used this? I am moving the battery to the opposite side and I am wondering if this will work in a mirror image application or not...
Old Mar 24, 2008 | 12:25 AM
dirt track racer 81's Avatar
it does not go where your battery is..its a replacement of your factory air intake and filter box
Old Mar 24, 2008 | 12:30 AM
Derek @ EDO's Avatar
FormerVendor
is that going to be used on this?
Old Mar 24, 2008 | 12:35 AM
Bismarck's Avatar
Originally Posted by Derek @ EDO
is that going to be used on this? :
Exactly, trying to get rid of the storm drain pipe that keeps sucking in hot air.
Old Mar 24, 2008 | 12:44 AM
FormerVendor
I see what your trying to do!
It should work. Your going to just sell the tube?
Old Mar 24, 2008 | 12:54 AM
Bismarck's Avatar
I guess I will.... Just wondering if it will fit, If you notice its not a perfect square, also will have to move the washer fluid reservior.
Old Mar 24, 2008 | 12:58 AM
FormerVendor
You might be able to cut the new box to fit with the washer reservoir...
Old Mar 25, 2008 | 10:17 PM
BigKID's Avatar
Let me know how it works for you. I want to do something similar for my KB.
Old Mar 25, 2008 | 10:26 PM
Bismarck's Avatar
Sure will....
Old Mar 26, 2008 | 07:40 AM
sickREDsierra's Avatar
i run that same s & b intake setup, but in the factory location.....
it should work fine on the other side though, as long as the openings are turned out and it gets moving air into it.
mine keeps my IAT's WAY lower than the stocker.... i monitored it once, but cant remember exactly how much...maybe 10-15 degrees or so?
Vortec350ss
Jan 12, 2016 10:36 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
turbo6c3
Oct 5, 2015 06:11 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
Closer_2001
Sep 24, 2015 09:15 PM
