Check Re-Calls & Service History Here
Old Dec 30, 2009 | 12:49 PM
  #911
Originally Posted by chris2000ss
could you check abs brake recall status on my 2002 silverado 2500 vin #1gcgk29u42z133269 . thanks
Hey bro, the speed sensor corrosion is still open....get that cehcked out my friend.
VEHICLE INFORMATION
Merchandising Model : CK25753 -2002 SILVERADO LS 2500 4WD EXT CAB Warranty Start Date : 10/13/2001
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : STOCKER CHEVROLET, INC.
701 BENNER PIKE
STATE COLLEGE , PA 16801-7313
(814) 238-4905
Selling Source : 13 - CHEVROLET
Site Code : 13806
Business Associate Code : 113528
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
RC 05068 FRONT WHEEL SPEED SENSOR CORROSION 09/22/2005 Open
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 10/13/2001 133 miles 10/13/2004 36133 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/13/2001 133 miles 10/13/2007 100133 miles
60/50000 FEDERAL EMISSION 10/13/2001 133 miles 10/13/2006 50133 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
09/26/2007 260301 # S5210 - PANEL, ROCKER - RIGHT - CORROSION PERFORATION REPAIR 53403 miles
07/05/2007 256854 # S5211 - PANEL, ROCKER - LEFT - CORROSION PERFORATION REPAIR 52093 miles
02/25/2005 118283 0 F0092 - UNIVERSAL JOINT, FRONT PROPELLER SHAFT - FRONT - REPLACE 31661 miles
01/06/2005 116525 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 31010 miles
10/23/2003 129912 # F0060 - SLIP JOINT, PROPELLER SHAFT - REPLACE 24386 miles
08/22/2003 115486 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 17251 miles
08/22/2003 115486 # B7290 - HOUSING/ADJUSTER ASSEMBLY, COMPOSITE HEADLAMP - RIGHT - RE 17251 miles
08/15/2003 115111 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 16437 miles
08/15/2003 115111 # B4300 - HANDLE AND REMOTE CONTROL, FRONT DOOR LOCK - RIGHT - R&R O 16437 miles
02/26/2003 014840 # N4187 - INSTRUMENT CLUSTER-ASSEMBLY RETURN TO AC DELCO ESC 2752 miles
02/24/2003 014840 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 2748 miles
09/06/2001 039320 # Z6999 - PDI RELATED FLUID ADDS 6 miles
08/28/2001 A33269 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Jan 2, 2010 | 12:26 PM
  #912
hawaiianstyle's Avatar
Default reduced engine power
Happy New Year!!!
Hey Torque_Wrench, is there anything out there that eliminates or fixes the reduced engine power warning that I get every so often, it's annoying and I could be going 65-70 on the interstate and bam, reduced engine power shows up on my DTC. Any info on this issue will be appreciated. By the way, I've checked all the connections to my MAF and the sensor on the TB.
Old Jan 4, 2010 | 07:02 AM
  #913
Originally Posted by hawaiianstyle
Happy New Year!!!
Wow brotha, without knowing any specifics of the case, I woulden't know where to start on this. Unless it's a programming issue.
Old Jan 16, 2010 | 04:03 PM
  #914
RYNO63SS's Avatar
Hey touque wrench.
Can you check mine? 1GTHK29U33E326090. Is there any thing saying service air bag?
Thanks bro!!!
Old Jan 17, 2010 | 01:28 PM
  #915
Dy Lon's Avatar
1GNEK13T65R125073
If you don't mind, looking for all the servis info, recalls, ect. On my tahoe. Speedo recall?? *crosses fingers*
Old Jan 18, 2010 | 08:34 AM
  #916
Originally Posted by RYNO63SS
Hey touque wrench.
Thanks bro!!!
No Air Bag TSB's and no air bag replacement...but you got one helluva service history!
VEHICLE INFORMATION
Merchandising Model : TK25753 -2003 SIERRA 2500 HD 4WD 4DR PICKUP Warranty Start Date : 10/24/2003
Delivering Dealer : MAZZEI PONTIAC-CADILLAC-BUICK-GMC TRUCK
PO BOX 519
ANTIOCH , CA 94509-0051
(925) 757-5600
Selling Source : 48 - GMC TRUCK
Site Code : 40105
Business Associate Code : 116697
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 10/24/2003 22 miles 10/24/2006 36022 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 10/24/2003 22 miles 10/24/2009 100022 miles
84/70000 CALIFORNIA SELECT COMPONENT 10/24/2003 22 miles 10/24/2010 70022 miles
60/50000 FEDERAL EMISSION 10/24/2003 22 miles 10/24/2008 50022 miles
60/50000 CALIFORNIA EMISSIONS 10/24/2003 22 miles 10/24/2008 50022 miles
CLAIM HISTORY
12/22/2009 242111 # T5680 - INSTRUMENT CLUSTER ASSEMBLY, GMT 800 SPECIAL COVERAGE BULL 69397 miles
12/21/2009 242111 # T5686 - 07187 - SPECIAL COVERAGE ADJUSTMENT - REPLACE & REPROGRAM 69045 miles
01/31/2006 204415 # E5131 - SPRING ASSEMBLY, REAR LEAF - LEFT - REPLACE 35964 miles
01/30/2006 204345 # R0760 - RADIO, REMOVE AND REPLACE 35942 miles
01/30/2006 204345 # J0357 - ROCKER ARM - ONE CYL - BOTH BANKS - REPLACE 35942 miles
01/26/2006 204256 # R0754 - RADIO RECEIVER-RETURN TO AC/DELCO ESC 35758 miles
01/26/2006 204256 # N4010 - LIGHTER ASSEMBLY, CIGARETTE - REPLACE 35758 miles
01/26/2006 204256 # R0762 - RECEIVER, RADIO - ORDER OR REMOVE 35758 miles
07/11/2005 199064 # J0350 - VALVE ROCKER ARM REPLACEMENT - RIGHT SIDE 29555 miles
04/21/2005 083855 # C9040 - FRONT SEAT BELT RETRACTOR REPLACEMENT 26474 miles
12/28/2004 078964 # H9991 - CUSTOMER CONCERN NOT DUPLICATED - BRAKES 21053 miles
12/28/2004 078964 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 21053 miles
12/28/2004 078964 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 21053 miles
12/28/2004 078964 # C7420 - LOCK, FOLDING SECOND SEAT CUSHION - R&R OR REPLACE 21053 miles
12/28/2004 078964 # N0110 - BATTERY REPLACEMENT 21053 miles
02/02/2004 066738 # K4290 - TRANSFER CASE OIL DRAIN OR FILL PLUG REPLACEMENT 5415 miles
02/02/2004 066738 # F2223 - DIFFERENTIAL CASE REPLACEMENT 5415 miles
12/09/2003 064834 # A1230 - FRONT SIDE DOOR REFINISH/CLEAR COAT - RIGHT SIDE 2838 miles
12/09/2003 064834 # B4660 - REAR SIDE DOOR LOCK REPLACEMENT - RIGHT SIDE 2838 miles
12/09/2003 064834 # Z7903 - 3-DAY COURTESY TRANSPORTATION 2838 miles
12/01/2003 064500 # H9991 - CUSTOMER CONCERN NOT DUPLICATED - BRAKES 2548 miles
12/01/2003 064500 # C3241 - FRONT SIDE DOOR PULL HANDLE REPLACEMENT - LEFT SIDE 2548 miles
12/01/2003 064500 # C6040 - ADJUSTER ASSEMBLY, FRONT SEAT POWER - BUCKET SEAT - PASSEN 2548 miles
05/05/2003 A26090 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old Jan 18, 2010 | 08:35 AM
  #917
Originally Posted by Dy Lon
1GNEK13T65R125073
Don't have any open re-calls my friend.
VEHICLE INFORMATION
Merchandising Model : CK15706 -2005 TAHOE 4WD Warranty Start Date : 09/03/2004
Delivering Dealer : STRICKLAND CHEVROLET, INC.
5719 BROADWAY ST
PEARLAND , TX 77581-7899
(281) 485-1495
Site Code : 30453
Business Associate Code : 114838
Vehicle Has No Current Record Of Outstanding Campaigns
SB 06049 ONSTAR H/W IS DIGITAL-CAPABLE. NO UPGRADE IS NEEDED. SEE TSB 06-08-46-008. 02/22/2007 See Bulletin
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID M2VE60WK XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 09/03/2004 2 miles 09/03/2007 36002 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/03/2004 2 miles 09/03/2010 100002 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/03/2004 2 miles 09/03/2012 80002 miles
36/36000 FEDERAL EMISSION 09/03/2004 2 miles 09/03/2007 36002 miles
CLAIM HISTORY
04/04/2005 192524 # E2020 - WHEEL ALIGNMENT MEASUREMENT 6167 miles
04/04/2005 192524 # C7930 - HANDLE, FOLDING THIRD SEAT QUICK RELEASE - R&R OR REPLACE 6167 miles
08/19/2004 A25073 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Jan 18, 2010 | 12:21 PM
  #918
DriftR's Avatar
Hey Torque Wrench, saw your Masonic symbol and wanted to commend you for helping others... added myself to the list, whatever you can find on 1GCEK14V7YE372154
Thankyou Sir!
Old Jan 18, 2010 | 02:41 PM
  #919
Thankyou Sir!
Hey brother...thanx for the Masonic compliments. I try to help everyone, anytime that I can.
Here's you a rundown of your vehcile.
VEHICLE INFORMATION
Merchandising Model : 1ZH69 -2009 MALIBU 1LT Warranty Start Date : 08/26/2008
BARS Order Type : 50 - FLEET
Delivering Dealer : TEAM ONE
12899 GARRETT HWY
OAKLAND , MD 21550-1162
(301) 334-9494
Site Code : 13127
Business Associate Code : 164454
RC 09041 SHIFT LEVER INDICATOR MAY NOT DISPLAY CORRECT GEAR N/A Closed
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 08/26/2008 10 miles 08/26/2011 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/26/2008 10 miles 08/26/2014 100010 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 08/26/2008 10 miles 08/26/2013 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/26/2008 10 miles 08/26/2016 80010 miles
36/36000 FEDERAL EMISSION 08/26/2008 10 miles 08/26/2011 36010 miles
CLAIM HISTORY
08/06/2009 069628 # E0716 - DIAGNOSTIC SYSTEM CHECK - TIRE PRESSURE MONITORING 29741 miles
08/06/2009 069628 # V2091 - 09041 - INSTALLATION OF TRANS SHIFT CABLE KIT & INSPECT & 29741 miles
09/04/2008 039205 I Z6999 - PDI RELATED FLUID ADDS 1 miles
08/25/2008 A45297 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Jan 18, 2010 | 10:35 PM
  #920
DriftR's Avatar
Could you double check that vin please... Should be a 2000 Chevy Silverado 4X4 RCLB?
It would be nice if I still had a warranty, even if it was a Malibu...
