Check Re-Calls & Service History Here
Old Oct 27, 2009 | 09:37 AM
  #841
FrEdDy's Avatar
THANKS, Torque Wrench.
Old Oct 27, 2009 | 09:39 AM
  #842
Originally Posted by JKmotorsports
Hope two isn't too much. I've always wondered about the service history on these:
1GNEC13T81R176842
1G6DM577240166874
TIA.
Well on the first one...no real service history...but it's got a ton of Service Bulletin advisories.....but they seem to have locked the keys up a couple of times...lol
VEHICLE INFORMATION
Merchandising Model : CK10753 -2009 SILVERADO 1500 4WD EXT CAB LT1 Warranty Start Date : 11/06/2008
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : RAMEY AUTOMOTIVE, INC.
2750 CLINCH ST
RICHLANDS , VA 24641-2114
(276) 964-2511
Selling Source : 13 - CHEVROLET
Site Code : 09391
Business Associate Code : 183562
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Type Number Description Posted Date Status
EI 08310 POOR A/C PERFORMANCE, NOT COLD ENOUGH, COMPRESSOR NOISE. REF. TSB 08-01-39-010 08/14/2009 See Bulletin
EI 09081 BODY MOUNTED WEATHER STRIP REPLACEMENT (REF. TSB 09-08-64-012) 04/01/2009 See Bulletin
EI 09085 FRONT SUSPENSION CLUNK, SQUEAK, RATTLE POPPING OR CREAK (REF TSB 09-03-08-006) 04/22/2009 See Bulletin
EI 09088 FRT OR RR DOOR WINDOW BINDS, MOVES SLOW/NOISY/OR INOP (TSB 09-08-64-015) 04/24/2009 See Bulletin
EI 09113 FRONT WINDSHIELD WIPER FUNCTION( REF. TSB 09-08-43-002) 05/15/2009 See Bulletin
EI 09117 RADIO INOPERATIVE OR NO DISPLAY(REF. TSB 09-08-44-012) 05/15/2009 See Bulletin
EI 09142 PAINT APPEARANCE, DIRT/ORANGE-PEEL/THIN,BLEED THRU/RUNS (REF. PIE 0005) 08/12/2009 See Bulletin
EI 09212 HVAC VENT TEMPERATURE DIFFERS FROM CONTROL SETTINGS (REF. PIE 0011) 08/31/2009 See Bulletin
EI 09215 REMOTE KEYLESS ENTRY (RKE) REPROGRAMMING (REFERENCE PIE 0014) 09/17/2009 See Bulletin
EI 09257 STABILITRAK INOPERATIVE (REFERENCE PIE 0021) 10/07/2009 See Bulletin
EI 09258 TRANSMISSION CONTROL MODULE (TCM) DTC P0741 (REFERENCE PIE 0022) 10/07/2009 See Bulletin
EI 09262 TRANS FLUID LEAK FROM OIL PUMP AREA/TORQUE CONVTR SEAL BLOWN OUT (PIE 0026) 10/19/2009 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID 383R12CA XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 11/06/2008 19 miles 11/06/2011 36019 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/06/2008 19 miles 11/06/2014 100019 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 11/06/2008 19 miles 11/06/2013 100019 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/06/2008 19 miles 11/06/2016 80019 miles
36/36000 FEDERAL EMISSION 11/06/2008 19 miles 11/06/2011 36019 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
04/22/2009 228737 # Z2081 - ROADSIDE SERVICE (LOCKOUT) 14800 miles
03/28/2009 172663 # Z2081 - ROADSIDE SERVICE (LOCKOUT) 13000 miles
12/12/2008 064609 # H0122 - FRONT BRAKE ROTOR REFINISHING 4041 miles
10/22/2008 063569 I Z6999 - PDI RELATED FLUID ADDS 2 miles
10/16/2008 A20713 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
© 2009 General Motors. All Rights Reserved.
Old Oct 27, 2009 | 09:42 AM
  #843
1GNEC13T81R176842
1G6DM577240166874
TIA.
The second ne...has no open re-calls...and not much of anyting to be worried about.
VEHICLE INFORMATION
Merchandising Model : 6DM69 -2004 CTS Warranty Start Date : 03/16/2004
Delivering Dealer : DAVID TAYLOR CADILLAC/BUICK
PO BOX 36428
HOUSTON , TX 77236-6428
(713) 777-7151
Selling Source : 12 - CADILLAC
Site Code : 39133
Business Associate Code : 119223
RC 04043 LOWER CONTROL ARM WASHER N/A Closed
RC 05004 INADVERTENT DRIVER AIRBAG DEPLOY WHEN IGNITION KEY TURNED TO ON POSITION N/A Closed
RC 05524 ECM EEPROM EXCESSIVE WRITES - REPROGRAM ECM N/A Closed
SB 06047 DETERMINE IF ONSTAR CAN BE UPGRADED AT GM GLOBALCONNECT-SEE TSB 05-08-46-006 02/21/2007 See Bulletin
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
48/50000 BUMPER TO BUMPER LIMITED WARRANTY 03/16/2004 10 miles 03/16/2008 50010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/16/2004 10 miles 03/16/2010 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/16/2004 10 miles 03/16/2012 80010 miles
48/50000 FEDERAL EMISSION 03/16/2004 10 miles 03/16/2008 50010 miles
CLAIM HISTORY
07/13/2005 061723 # V1302 - 05004 - REPLACE SDM 17486 miles
06/22/2005 060288 # V1321 - 05524 - REPROGRAM ECM 16638 miles
05/29/2005 059709 # Z6720 - CADILLAC-COST OF TECH. TO MAKE ROADSIDE SRVC CALLS 15490 miles
05/29/2005 061098 # Z2085 - ROADSIDE SERVICE (PREMIUM) 15490 miles
11/12/2004 039842 # V1232 - 04043 - INSPECT AND REPLACE BOTH FRONT LOWER CONTROL ARM ( 8503 miles
11/12/2004 039842 # Z7901 - 1-DAY COURTESY TRANSPORTATION 8503 miles
11/12/2004 039842 # E2020 - WHEEL ALIGNMENT MEASUREMENT 8503 miles
11/12/2004 039842 # B7766 - ROCKER PANEL REAR MOLDING REPLACEMENT 8503 miles
03/03/2004 A66874 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Oct 27, 2009 | 01:05 PM
  #844
JKmotorsports's Avatar
VEHICLE INFORMATION
2750 CLINCH ST
(276) 964-2511
Site Code : 09391
CLAIM HISTORY
Thanks a bunch for the info, but something somewhere isn't right. The VIN is from my 01 Tahoe LT. The info is for an 09 Silvy
The 2nd vin for my Caddy u looked up was correct. Just confused about my trk. Maybe accidentally entered a wrong digit somewhere? I doubled checked the VIN I posted. If you get time to double check it for me, then cool. If not, no worries, that's cool also man.
Thnx for taking the time to look these up for me in the first place.
Old Oct 27, 2009 | 01:21 PM
  #845
Hmmmmm..intresting...let me run it again.
Okay...here's it again...
VEHICLE INFORMATION
Merchandising Model : CC15706 -2001 TAHOE 2WD Warranty Start Date : 08/26/2001
Delivering Dealer : COVERT CHEVROLET, BUICK, PONTIAC, GMC
PO BOX J
BASTROP , TX 78602-1977
(512) 303-2311
Site Code : 30148
Business Associate Code : 114878
RC 02039 REARWARD FOLDING HEAD RESTRAINTS PINCH POINT N/A Closed
SB 06048 ONSTAR H/W IS ANALOG ONLY-CANNOT BE UPGRADED TO DIGITAL-SEE TSB 06-08-46-007 01/23/2007 See Bulletin
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 08/26/2001 21 miles 08/26/2004 36021 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/26/2001 21 miles 08/26/2007 100021 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/26/2001 21 miles 08/26/2009 80021 miles
36/36000 FEDERAL EMISSION 08/26/2001 21 miles 08/26/2004 36021 miles
CLAIM HISTORY
08/28/2006 117414 # J6360 - POWERTRAIN CONTROL MODULE REPLACEMENT 73513 miles
08/28/2006 117414 # T2020 - TOWING 73513 miles
07/29/2006 F06512 # Z8020 - ONSTAR - TOW 71000 miles
02/09/2004 998196 # Z8015 - ROADSIDE SERVICE (FLAT TIRE) 34000 miles
01/03/2004 379561 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 33264 miles
01/03/2004 379561 # H3052 - SHOE, REAR DISC PARKING BRAKE - BOTH - REPLACE 33264 miles
01/03/2004 379561 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 33264 miles
11/04/2003 105574 # V0894 - 02039 - INSTALL PROTECTIVE COVERS 30518 miles
09/18/2001 097156 # C2860 - FRONT FLOOR CONSOLE REPLACEMENT 932 miles
09/18/2001 097156 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 932 miles
03/21/2001 A76842 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Oct 27, 2009 | 10:07 PM
  #846
Awesome, man. Thanks for the info
Old Oct 27, 2009 | 10:29 PM
  #847
catalac's Avatar
Registered User
Hi Wondering if you could query:
2006 GMC 2500HD 1GTHK29U56E174897
Thnx
Old Oct 28, 2009 | 09:21 AM
  #848
Thnx
No open re-calls...and not a bad service history. But you have had a PCM go down...
VEHICLE INFORMATION
Merchandising Model : TK25753 -2006 SIERRA SLE 2500HD 4WD Warranty Start Date : 01/20/2006
Delivering Dealer : SHAW GMC PONTIAC BUICK HUMMER LTD.
4620 BLACKFOOT TRAIL S.E.
CALGARY , AB T2G4G2
(403) 243-4200
Selling Source : 14 - GM OF CANADA
Site Code : 82048
Business Associate Code : 120472
Vehicle Has No Current Record Of Outstanding Service Information
OnStar Equipped No OnStar Status N/A Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID YMAXD04D XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/60000 BUMPER TO BUMPER LIMITED WARRANTY 01/20/2006 20 kilometres 01/20/2009 60020 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/20/2006 20 kilometres 01/20/2012 160020 kilometres
60/80000 FEDERAL EMISSION 01/20/2006 20 kilometres 01/20/2011 80020 kilometres
CLAIM HISTORY
07/12/2007 007803 # E9050 - POWER STEERING PUMP REPLACEMENT 58635 kilometres
02/20/2007 000292 # B1540 - LATCH, HOOD - R&R OR REPLACE 41463 kilometres
02/20/2007 000292 # J6354 - POWERTRAIN CONTROL MODULE ENGINE REPROGRAMMING WITH SPS 41463 kilometres
02/20/2007 000292 # R0942 - RADIO FRONT SIDE DOOR SPEAKER REPLACEMENT - RIGHT SIDE 41463 kilometres
11/18/2005 A74897 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Oct 28, 2009 | 05:57 PM
  #849
catalac's Avatar
Registered User
Thanks very much!
Do you know what the acronym on the reprogramming "SPS" means or why they may have had to reprogram?
Old Oct 29, 2009 | 06:57 AM
  #850
Your PCM data may have been corrupted, but physically the PCM could have benn good. All they needed to do was possibly just a simple Re-Flash of the new PCM data to fix the concern.
