Check Re-Calls & Service History Here
Old Aug 10, 2009 | 07:10 AM
  #751
Originally Posted by trxmxzx
hey torque wrench i need some help here, i have a problem with a buddys dads yukon. His traction control is going nuts and its causing him to almost get in accidents.
his traction control kicks in at very low speeds he took it to the dealer and they said they cant help him B.S. in my opinion. i just want to see if there was a recall of some sort on this problem and they dont want to fix it!
thanks a lot Keith
vin# 3GKFK16Z04G231583
2004 gmc yukon xl
Are you meaning your friends "traction control" or his "ABS" is going nuts? Give me a description of the symptom that it's exhibiting, that way I can further diagnose it.
I've searched the GM SI system and there's no TSB's related to just what you have described. So if you can get me more info, Id be more than glad to help you out.
Old Aug 10, 2009 | 08:20 AM
  #752
5.3sierra's Avatar
torque wrench can you check on this vin# I just bought the truck. 06 sierra vin#2gtec13t461216438
Old Aug 10, 2009 | 12:04 PM
  #753
trxmxzx's Avatar
13 Second Truck Club
I thought it was the ABS also, but there is no light for it and when you take off and it says power reduced on the display, when it happens. he can turn off the traction control and it will be fine, but then there is a light on reminding you its off.
I wonder if its the wheel sensors in the front?
thanks a lot
keith
Old Aug 11, 2009 | 08:45 AM
  #754
VEHICLE INFORMATION
Merchandising Model : TK10706 -2007 YUKON DENALI - AWD Warranty Start Date : 08/27/2007
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : RAMEY AUTOMOTIVE, INC.
2750 CLINCH ST
RICHLANDS , VA 24641-2114
(276) 964-2511
Selling Source : 48 - GMC TRUCK
Site Code : 53430
Business Associate Code : 183562
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 08048 HEATED WINDSHIELD WASHER MODULE SHORT CIRCUIT - ADD WIRE HARNESS N/A Closed
SERVICE INFORMATIONAL ITEMS
EI 07140 SERVICE SUSPENSION MESSAGE (ECU) - REF. TSB 07-03-11-001 05/10/2007 See Bulletin
EI 09081 BODY MOUNTED WEATHER STRIP REPLACEMENT (REF. TSB 09-08-64-012) 04/01/2009 See Bulletin
EI 09113 FRONT WINDSHIELD WIPER FUNCTION( REF. TSB 09-08-43-002) 05/15/2009 See Bulletin
ON STAR AND XM SATELLITE RADIO INFORMATION
OnStar Equipped Yes OnStar Status Active Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID WCL0T0W3 XM Status Active Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 08/27/2007 832 miles 08/27/2010 36832 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/27/2007 832 miles 08/27/2013 100832 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 08/27/2007 832 miles 08/27/2012 100832 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/27/2007 832 miles 08/27/2015 80832 miles
36/36000 FEDERAL EMISSION 08/27/2007 832 miles 08/27/2010 36832 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/30/2009 068717 # N9995 - CUSTOMER CONCERN NOT DUPLICATED - ELECTRICAL 27148 miles
04/29/2009 067316 # N5525 - ASSIST STEP CONTROLLER REPLACEMENT 25862 miles
04/29/2009 067316 # N6636 - ENTRY CONTROL SYSTEMS WIRING AND/OR CONNECTOR REPAIR OR RE 25862 miles
04/29/2009 067316 # V1993 - 08048A - JUMPER HARNESS INSTALLATION 25862 miles
04/29/2009 067316 # H0120 - ROTOR ASSEMBLY - FRONT - RIGHT - REPLACE 25862 miles
04/29/2009 067316 # R9995 - CUSTOMER CONCERN NOT DUPLICATED - CELLULAR, ENTERTAINMENT, 25862 miles
10/13/2008 063387 # R9731 - 61433 REPROGRAM A?? ARTICULATING RUNNING BOARD CONTROLLER 14000 miles
04/28/2008 059809 # B0485 - FRONT AIR DEFLECTOR REPLACEMENT 11698 miles
04/28/2008 059809 # N6614 - INTERIOR/REAR COMPARTMENT LIGHTING WIRING AND/OR CONNECTOR 11698 miles
04/15/2008 059496 # H0120 - ROTOR ASSEMBLY - FRONT - RIGHT - REPLACE 11554 miles
10/08/2007 055566 # C6870 - PASSENGER SEAT CUSHION COVER REPLACEMENT 2209 miles
10/08/2007 055566 # E0420 - WHEEL REPLACEMENT 2209 miles
02/28/2007 A30869 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Old Aug 11, 2009 | 08:54 AM
  #755
thanks a lot
keith
More than likely it is the front wheels speed (ABS) sensors. There is a TSB warning of contamination of the ABS sensors in the wheel hubs. So he may very well have some corrosuion on them, and need them cleaned.
Old Aug 11, 2009 | 11:26 AM
  #756
trxmxzx's Avatar
awesome thanks, ill let him know! keep up the good work
Old Aug 11, 2009 | 11:49 PM
  #757
ahhwataday's Avatar
Originally Posted by Torque_Wrench
...LOL...yeah bro, a GM dealer will fix those 2 re-calls for you free of charge. Yeah, I'm about 6 hours west of you...I'm in Richlands Virginia.
Damn 6 hours away and still in VA? haha thats nuts.
I got my cables today and they told me they would only inspect my front sensor. Not fix or replace it. Is this F'd up or are they tellin the truth?
Old Aug 12, 2009 | 08:02 AM
  #758
The will have to inspect it for free...yes. If they find that the ABS sensors have corrosion on them, then they will have to fix them for free because it's a saftey Re-Call from GM. If the ABS sensors don't have a corrosion build up on them then they will bolt her back up and ship it out the door.
I personally just did the ABS Sensor Inspection and cleaning on my 2006 Silverado yesterday...lol. Took me about an hour.
So, being in Va....you ever get down to the Bristol Motor Speedway to Thunder Valley for the ol' Super Chevy Show or any of the weekend warrion street races?
Old Aug 19, 2009 | 12:48 PM
  #759
Hawaiian_Built's Avatar
12 Second Club
Hey Torque, Can you check out my vin 1GTEC14TX3Z295681M , wanna know how bad it is. thanks in advance
Old Aug 20, 2009 | 08:34 AM
  #760
Hey bro, it's not that bad. No open re-calls and not a bad work history.
VEHICLE INFORMATION
Merchandising Model : TC15703 -2003 SIERRA 1500 2WD REG CAB PICKUP Warranty Start Date : 04/24/2003
Delivering Dealer : ALFRED MATTHEWS CADILLAC/PONTIAC/GMC
PO BOX 577287
MODESTO , CA 95357-7287
(209) 577-0140
Site Code : 40483
Business Associate Code : 117735
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
Vehicle Has No Current Record Of Outstanding Service Information
Vehicle Has No Associated On Star or XM Radio Information.
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 04/24/2003 7 miles 04/24/2006 36007 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 04/24/2003 7 miles 04/24/2009 100007 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 04/24/2003 7 miles 04/24/2011 80007 miles
84/70000 CALIFORNIA SELECT COMPONENT 04/24/2003 7 miles 04/24/2010 70007 miles
36/50000 CALIFORNIA EMISSIONS 04/24/2003 7 miles 04/24/2006 50007 miles
CLAIM HISTORY
06/30/2005 109083 # F2023 - SEAL, PINION SHAFT OIL - REAR DIFFERENTIAL - REPLACE 35552 miles
06/30/2005 109083 # L0618 - FUEL TANK PRESSURE SENSOR REPLACEMENT 35552 miles
05/09/2005 056828 # J9995 - CUSTOMER CONCERN NOT DUPLICATED - EMISSIONS 31050 miles
05/09/2005 056828 # N1720 - FUSE REPLACEMENT 31050 miles
05/09/2005 056828 # N2117 - SWITCH - SWITCH MODULE, FRONT DOOR - LEFT - REPLACE 31050 miles
03/18/2005 067292 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 31027 miles
03/04/2004 051034 # N6642 - HVAC SYSTEM WIRING AND/OR CONNECTOR REPAIR OR REPLACEMENT 21189 miles
03/31/2003 A95681 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
