Check Re-Calls & Service History Here
#722
Hi...
I was wondering if you could do your magic and check the service history and recall history of this grand prix.
1G2WR5210XF207292
thanks alot in advance.....
1G2WR5210XF207292
#723
#724
Hi...
1G2WR5210XF207292
1G2WR5210XF207292
Merchandising Model : 2WR69 Warranty Start Date : 08/04/1999
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : STAMPEDE PONTIAC BUICK (1988) LTD.
1110 - 9TH AVENUE S.W.
CALGARY , AB T2P1M1
(403) 265-2277
Selling Source : 14 - GM OF CANADA
Site Code : 82045
Business Associate Code : 120469
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 07035 ENGINE COMPARTMENT FIRE N/A Closed
RC 99050 STARTER MOTOR FAILURES - INSPECT/REPLACE STARTER MOTOR N/A Closed
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/60000 BUMPER TO BUMPER LIMITED WARRANTY 08/04/1999 329 kilometres 08/04/2002 60329 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/04/1999 329 kilometres 08/04/2005 160329 kilometres
96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/04/1999 329 kilometres 08/04/2007 130329 kilometres
36/60000 FEDERAL EMISSION 08/04/1999 329 kilometres 08/04/2002 60329 kilometres
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/02/2008 712853 # V1806 - 07035 - REPLACE ENGINE LEFT (FRONT) VALVE COVER GASKET AND 111670 kilometres
11/01/2004 603562 0 N2144 - SWITCH - DOOR WINDOW - RIGHT FRONT - REPLACE 83459 kilometres
11/01/2004 603562 0 N4172 - MODULE, DRIVER INFORMATION CENTER DISPLAY (INSTRUMENT PANE 83459 kilometres
11/01/2004 603562 0 R0760 - RADIO, REMOVE AND REPLACE 83459 kilometres
06/02/2003 566291 0 J4640 - STARTER REPLACEMENT 66950 kilometres
04/09/2003 562448 0 N2320 - IGNITION AND START SWITCH REPLACEMENT 64525 kilometres
04/09/2003 562448 0 N6630 - WIRING AND/OR CONNECTOR - TRANSMISSION/TRANSFER CASE/TRANS 64525 kilometres
04/09/2003 562448 0 Z7901 - 1-DAY COURTESY TRANSPORTATION 64525 kilometres
11/06/2000 354608 # J4100 - GENERATOR REPLACEMENT 25995 kilometres
11/06/2000 354608 # V0376 - 1998 & 1999 PN,OD,BK, - STARTER MOTOR FAILURES, REPL/REPR 25995 kilometres
11/06/2000 354608 # Z7901 - 1-DAY COURTESY TRANSPORTATION 25995 kilometres
09/02/1998 A07292 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
#725
VEHICLE INFORMATION
Merchandising Model : CK25753 -2003 SILVERADO LS 2500HD 4WD Warranty Start Date : 09/27/2003
Delivering Dealer : NICHOLSON CHEVROLET (1977) LTD.
7215 ARGYLL ROAD
EDMONTON , AB T6C4J2
(780) 465-6471
Site Code : 82100
Business Associate Code : 120502
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
RC 05546 15,000 MILE - 24,000 KM FUEL FILTER CHANGE **IN EFFECT UNTIL SEPT. 30, 2006** N/A Closed
SB 06047 DETERMINE IF ONSTAR CAN BE UPGRADED AT GM GLOBALCONNECT-SEE TSB 05-08-46-006 02/21/2007 See Bulletin
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped No XM Radio ID N/A XM Status N/A Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/60000 BUMPER TO BUMPER LIMITED WARRANTY 09/27/2003 23 kilometres 09/27/2006 60023 kilometres
72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/27/2003 23 kilometres 09/27/2009 160023 kilometres
60/160000 FEDERAL EMISSION 09/27/2003 23 kilometres 09/27/2008 160023 kilometres
60/160000 GM DIESEL ENG IN LD VEH WITH $100 DEDUCT AFTER BUMPER TO BUMPER LIMITED WARRANTY 09/27/2003 23 kilometres 09/27/2008 160023 kilometres
CLAIM HISTORY
04/21/2008 S27184 # T5680 - INSTRUMENT CLUSTER ASSEMBLY, GMT 800 SPECIAL COVERAGE BULL 177380 kilometres
04/17/2008 261866 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 177380 kilometres
11/09/2006 173553 # T5603 - 04039 - REPLACE ALL 8 FUEL INJECTORS - REFER TO TSB 04-06- 156000 kilometres
05/29/2006 189175 # J0511 - HEAD, CYLINDER - LEFT BANK - REPLACE 148412 kilometres
05/29/2006 189175 # V1380 - 05546 - REPLACE FUEL FILTER 148412 kilometres
05/29/2006 189175 # Z7903 - 3-DAY COURTESY TRANSPORTATION 148412 kilometres
05/20/2005 150966 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 135411 kilometres
03/01/2005 729788 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 133963 kilometres
01/28/2005 728729 # J5650 - FUEL INJECTOR REPLACEMENT 133963 kilometres
08/24/2004 723942 0 E5168 - REAR SPRING, INSULATOR, AND JOUNCE BUMPER REPLACEMENT 91868 kilometres
08/24/2004 723942 0 N3520 - WINDSHIELD WIPER MOTOR REPLACEMENT 91868 kilometres
08/24/2004 723942 # N4180 - INSTRUMENT CLUSTER REPLACEMENT 91868 kilometres
05/20/2004 721119 # C6860 - FRONT SEAT CUSHION COVER AND PAD REPLACEMENT 62601 kilometres
05/20/2004 721119 0 F1003 - UNIVERSAL JOINT, REAR PROPELLER SHAFT - REAR - REPLACE 62601 kilometres
05/20/2004 721119 0 F1441 - OUTPUT SHAFT SEAL REPLACEMENT - LEFT SIDE 62601 kilometres
04/22/2004 R03053 # R0760 - RADIO, REMOVE AND REPLACE 51794 kilometres
04/21/2004 720141 # E8047 - STEERING LINKAGE INNER TIE ROD REPLACEMENT - BOTH SIDES 51794 kilometres
04/21/2004 720141 # F1672 - SEAL, HUB OIL - REAR AXLE - BOTH - REPLACE 51794 kilometres
04/21/2004 720141 # N0657 - REAR LICENSE PLATE LAMP BULB REPLACEMENT 51794 kilometres
04/21/2004 720141 # N0761 - BULBS, STOP, TAIL, AND TURN LAMP (LEFT) - REPLACE 51794 kilometres
04/21/2004 720141 # N0850 - FRONT FOG LAMP BULB REPLACEMENT 51794 kilometres
04/21/2004 720141 # R0762 - RECEIVER, RADIO - ORDER OR REMOVE 51794 kilometres
04/21/2004 720141 # R0763 - RECEIVER, RADIO - INSTALL 51794 kilometres
01/09/2004 716893 # D1810 - AIR INLET VALVE ACTUATOR REPLACEMENT 27266 kilometres
01/09/2004 716893 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 27266 kilometres
12/19/2003 716427 # D1807 - ACTUATOR AND/OR MOTOR, ELECTRIC - UPPER AND/OR LOWER MODE 22634 kilometres
12/19/2003 716427 # J4100 - GENERATOR REPLACEMENT 22634 kilometres
12/19/2003 716427 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 22634 kilometres
12/16/2003 716315 # F2122 - DIFFERENTIAL CARRIER RECONDITIONING 22008 kilometres
12/16/2003 716315 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 22008 kilometres
12/03/2003 715950 # B7540 - WINDSHIELD REVEAL MOLDING REPLACEMENT 20112 kilometres
12/03/2003 715950 # N3215 - FRONT SIDE DOOR LOCK ACTUATOR REPLACEMENT - LEFT SIDE 20112 kilometres
12/03/2003 715950 # Z7911 - 2-WAY SHUTTLE COURTESY TRANSPORTATION 20112 kilometres
06/16/2003 046706 # N4800 - BODY CONTROL MODULE REPLACEMENT 18 kilometres
04/28/2003 A18997 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
#726
thanks man really doesn't look bad considering last time it was in the shop for a major repair was 2006... considering the list for my truck i'm driving right now is 5 times as long
#727
#728
here is the queen of all shop queens my current truck till tomorrow
1GCGK13U33F221039
1GCGK13U33F221039
LOL...damn dude, that service history reads like a Stephen King novel.
#730
Can you look up this old hoe I'm looking at? 1GNEK13K0SJ361333
VEHICLE INFORMATION
Merchandising Model : CK10706 Warranty Start Date : 03/24/1995
BARS Order Type : 0 - ALL ORDER TYPES (FOR WFP USE)
Delivering Dealer : ELCO CHEVROLET/ENTERPRISE FLEET SVCS
2650 SOUTH HANLEY ROAD/STE 300
SAINT LOUIS , MO 63144-2590
(314) 256-5117
Selling Source : 13 - CHEVROLET
Site Code : 03274
Business Associate Code : 111304
Vehicle Has No Current Record Of Outstanding Campaigns
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 03/24/1995 10 miles 03/24/1998 36010 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 03/24/1995 10 miles 03/24/2001 100010 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/24/1995 10 miles 03/24/2003 80010 miles
36/36000 FEDERAL EMISSION 03/24/1995 10 miles 03/24/1998 36010 miles
CLAIM HISTORY
01/18/2001 127526 # V0229 - 94-96 C/K, S/T- WINDSHIELD WIPER MOTOR FAILURES 94058 miles
