Check Re-Calls & Service History Here
#691
Thanks for the run down! And yeah, they tried to do something. Before I bought the truck, I asked several times to see the paperwork that showed the work performed included in their "recondition package"...and they never could cough it up. First time was when I initially went to see the truck on a Saturday, but supposedly the office that controlled the requested info was out on Saturdays. Anyway, I ended up getting a really good deal on it...they wanted some $11500 out the door, and after a bit of "dealing"...I got it out the door for $8450. Just recently I was laying down a coat of wax and noticed the body side molding "paint lines", which is what really kinda got me wondering if something had really happened to the truck that I didn't know about. Your report shows though that it was indeed replaced under warranty. At any rate, thanks again for the in depth report. Definitely helped out!!!
Not a problem friend! Anyway I can help out....I'll do it.
#692
Hey guys,
If you'd like to check the Re-Calls or your Service History & Vehicle Build of your GM Truck or Car, then you've came to the right place!
Post your questions along with your VIN # in this thread, and I'll plug them in here at work and reply with your status. I can check all re-call status, warranty status & coverage, service history along with RPO Options and etc.
I'll monitor the thread diffrent time over each day, so I should reply to your post within minutes.
Hope this helps you guys out....thanx!
Torque_Wrench
Torque_Wrench
vin: 1GCEK19T72E184118
I need to know if I qualify for any more Recalls and any other helpful info. you can give me.
Plus, I'm having a service 4WD issue. push 2wd button it goes out of 4wd but feels like it's still locked in.
Thanks,
Mike
#693
I have a 2002 chevrolet silverado 1500 4wd ext.cab 5.3l milage: 86025
Thanks,
Mike
Thanks,
Mike
VEHICLE INFORMATION
Merchandising Model : CK15753 -2002 SILVERADO LS 1500 4WD EXT CAB Warranty Start Date : 01/07/2002
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MARTIN CHEVROLET-OLDSMOBILE, INC.
505 EAST MAIN STREET
ELKLAND , PA 16920-1212
(814) 258-7127
Selling Source : 13 - CHEVROLET
Site Code : 15171
Business Associate Code : 130784
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
RC 05068 FRONT WHEEL SPEED SENSOR CORROSION 09/22/2005 Open
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 01/07/2002 130 miles 01/07/2005 36130 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 01/07/2002 130 miles 01/07/2008 100130 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 01/07/2002 130 miles 01/07/2010 80130 miles
36/50000 CALIFORNIA EMISSIONS 01/07/2002 130 miles 01/07/2005 50130 miles
84/70000 CALIFORNIA SELECT COMPONENT 01/07/2002 130 miles 01/07/2009 70130 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/13/2005 358752 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 40494 miles
05/03/2004 064308 # D3083 - HOSES AND/OR LINES, REFRIGERANT - CONDENSER TO EVAPORATOR 33421 miles
01/29/2004 063429 # C9201 - BELT, SEATBELT RETRACTOR (REAR OR ROW 1) (LEFT) - REPLACE 30058 miles
09/13/2003 062140 # B9613 - FRONT FOG LAMP REPLACEMENT - LEFT SIDE 25925 miles
09/13/2003 062140 # C9280 - REAR SEAT BELT REPLACEMENT 25925 miles
09/13/2003 062140 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 25925 miles
12/14/2001 A84118 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#694
From: as far away from Koonerville as humanly possible
TW, would appreciate getting the rundown on this truck whenever you have some time.
1GCEK14077Z642947
1GCEK14077Z642947
#695
1GCEK14077Z642947
1GCEK14077Z642947
VEHICLE INFORMATION
Merchandising Model : CK10703 -2007 SILVERADO 1500 4WD REG CAB LT1 Warranty Start Date : 08/20/2007
Delivering Dealer : O RIELLY CHEVROLET, INC.
PO BOX 12828
TUCSON , AZ 85732-2828
(520) 747-8000
Site Code : 39222
Business Associate Code : 114654
Vehicle Has No Current Record Of Outstanding Campaigns
SB 09074 POLICIES FOR USED VEHICLES PURCHASED THRU GM AUCTIONS (REF. TSB 09-00-89-017) 04/01/2009 See Bulletin
EI 09081 BODY MOUNTED WEATHER STRIP REPLACEMENT (REF. TSB 09-08-64-012) 04/01/2009 See Bulletin
OnStar Equipped Yes OnStar Status Inactive Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID 1WDZU0CG XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 08/20/2007 31 miles 08/20/2010 36031 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 08/20/2007 31 miles 08/20/2013 100031 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 08/20/2007 31 miles 08/20/2015 80031 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 08/20/2007 31 miles 08/20/2012 100031 miles
36/36000 FEDERAL EMISSION 08/20/2007 31 miles 08/20/2010 36031 miles
CLAIM HISTORY
06/07/2007 A42947 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
#696
Thank you sir!
#697
I would like to see a copy of or at least get the gyst of TSB 03-02-34-001A.
My mom's 02 Yukon is having some steering issues and I want to know if this is the fix. Apparently there's a grease kit for the intermediate shaft that could be a cure too, but I'll start another thread for that. I thought the power steering pump was the issue, but no dice.
I'm not sure if you can look this info up, but I'm having a helluva time. Apparently GM guards thier TSB's.
This thread seems like the right place to ask.
#698
What about a '07 Silverado with 43,000 miles? Any recalls or anything else worth knowing about?
Vin#:3GCEK13MX7G501908
Thanks!
Thanks!
#699
This thread seems like the right place to ask.There is a TSB on this problem, hence my sticky thread calle "Thumping or Knock in your Steering Wheel". The fix is now to replace the Upper Intermediate Steering Shaft if your vehicle exibits the thumping or vibration afore mentioned. The Lube Kit from GM is no longer available or is suggested for repair. GM suggest you replace the assembly and the part# is 19153614
#700
Thanks!
Thanks!
VEHICLE INFORMATION
Merchandising Model : CK10543 -2007 SILVERADO 1500 4WD CREW CAB LT2 Warranty Start Date : 02/13/2007
BARS Order Type : 60 - RETAIL - SOLD
Delivering Dealer : CUTSHAW CHEVROLET INC
PO BOX 279
GRAPELAND , TX 75844-0279
(936) 687-2014
Site Code : 07545
Business Associate Code : 112323
YT 07033 SERVICE UPDATE - INVENTORY & CUST. VEHS-BATTERY RUNDOWN-*EXP W/BASE WARRANTY* N/A Closed
XM Equipped Yes XM Radio ID 5EP8K0RY XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 02/13/2007 15 miles 02/13/2010 36015 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 02/13/2007 15 miles 02/13/2013 100015 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 02/13/2007 15 miles 02/13/2015 80015 miles
60/100000 POWERTRAIN COVERAGE LIMITED WARRANTY 02/13/2007 15 miles 02/13/2012 100015 miles
36/36000 FEDERAL EMISSION 02/13/2007 15 miles 02/13/2010 36015 miles
CLAIM HISTORY
02/22/2007 125323 # B0140 - FRONT LICENSE PLATE BRACKET REPLACEMENT 755 miles
02/22/2007 125323 G B0140 - FRONT LICENSE PLATE BRACKET REPLACEMENT 755 miles
02/12/2007 125160 # Y0152 - 07033 - SERVICE UPDATE - REPROGRAM BCM 2 miles
01/22/2007 A01908 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
