Check Re-Calls & Service History Here
Old Sep 22, 2008 | 11:41 AM
  #531
Originally Posted by johnny elohssa
Hey Torque wrench, I got a 95 GMC Sierra. VIN 2GTEK19K7S1567128. I'D really like the buildsheet, and anything else you got on it. Thanks alot.
Here ya go friend.
VEHICLE INFORMATION
Merchandising Model : TK10753 Warranty Start Date : 07/06/1995
BARS Order Type : 0 - ALL ORDER TYPES (FOR WFP USE)
Delivering Dealer : CREST, INC.
399 WASHINGTON STREET
WOBURN , MA 01801-2116
(781) 935-1111
Selling Source : 48 - GMC TRUCK
Site Code : 06548
Business Associate Code : 117949
Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Vehicle Has No Current Record Of Outstanding Campaigns
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 07/06/1995 8 miles 07/06/1998 36008 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 07/06/1995 8 miles 07/06/2001 100008 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 07/06/1995 8 miles 07/06/2003 80008 miles
36/36000 FEDERAL EMISSION 07/06/1995 8 miles 07/06/1998 36008 miles
36/50000 CALIFORNIA EMISSIONS 07/06/1995 8 miles 07/06/1998 50008 miles
84/70000 CALIFORNIA SELECT COMPONENT 07/06/1995 8 miles 07/06/2002 70008 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
06/12/2003 068933 # V1015 - 03023 - INSTALL WINDSHIELD WASHER PULSE CONTROL MODULE 94561 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 2996 kg (6606 lb) Order Number : K61089
Build Date : 06/20/1995 Build Plant : 2S153
GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
OPTION CODES
AE7 AJ1
AM7 AU3
A20 A31
BZY B32
B33 B85
B96 C5S
C60 DF2
E63 FK2
FK3 F44
F51 GT4
JB6 KC4
KNP K34
K60 L05
M30 NA1
NA5 NG1
NP5 NRQ
N33 OSG
PF4 RSA
R9A SLL
TFE UM6
UQ5 VB3
VG3 VK3
VR4 VXS
V22 V73
XBK YBK
YD3 YD6
YE9 ZBK
ZQ2 ZQ3
ZY2 Z82
Z88 1SC
1SZ 107
13D 13I
38U 6GF
7GF 96L
Now, it seems to me that the VIN number you gave me is either too new and it's not been entered into GM's database yet as to the explanations of the RPO Codes. This does happen from time to time...and I do see this alot. Just check back in about 15 days.
Old Sep 22, 2008 | 11:43 AM
  #532
Originally Posted by Fogle07
1GCEC14RVZ191377
everything you can get on it. thanks
Your VIN number is incomplete. You need 17 digits to have a valid VIN number.
Old Sep 22, 2008 | 03:26 PM
  #533
Fogle07's Avatar
sorry left one out.
1GCEC14R3VZ191377
Old Sep 22, 2008 | 03:43 PM
  #534
venomhp's Avatar
Hey Torque Ive got two questions for you- could I get a build sheet as well since its the popular thing to do anyway VIN# 2GCEK19T521192977
Also I had my tail gate straps replaced but I think my tailgate was bent before they replaced them because one of them snapped, will gm replace it?
Old Sep 22, 2008 | 04:13 PM
  #535
03silveradoLS's Avatar
any chance you can do a check on this truck. its not mine but if its clean i may buy it. thanks
anything you can dig up on it would be great
1GCEK14T34Z113288
Old Sep 23, 2008 | 09:22 AM
  #536
sorry left one out.
1GCEC14R3VZ191377
Dude, something is wrong with this vin#. What year is this thing, a 1997? GM won't take the VIN. Somehting is array.
Old Sep 23, 2008 | 09:29 AM
  #537
Okay, got you the build sheet below. Now, as to answer your question as to if GM will replace your tailgate? Probably not a chance. First a series of things happened that most likely killed any chance you had. If it was bent before, you should have had it documented either at the time of having the re-call done, or before. Second, you would have needed a picture of said problem with a date in it. Third, GM has stated before that damage may occur onl;y if the cables break with weight on the gate itself. So odds are they will deny any claim of the gate warping from weight applied to it because the cables won't stretch, they'll just snap. Then they would tell you that your warp is cause by putting too much weioght on your gate in the open position, because it does have a weight limit. Hope this helps. It's probably not what you wanted to hear, but....hey...I'm a staright shooter.
VEHICLE BUILD
Merchandising Model : CK15753 -2002 SILVERADO LT 1500 4WD EXT CAB
Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : DQGVR3
Build Date : 10/17/2001 Build Plant : 22153
OPTION CODES
AG1 - SIX-WAY POWER DRIVER SEAT AG2 - 6-WAY POWER DRIVER & PASS SEATS
AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT
AN3 - FRONT BUCKETS WITH POWER ADJ. AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
AU3 - POWER DOOR LOCK SYSTEM A31 - POWER WINDOWS
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B85 - BRIGHT BODY SIDE MOLDINGS
C49 - ELECTRIC REAR WINDOW DEFOGGER C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
C7H - 6,400 LB GVW RATING DF5 - INT R/V MIRROR, LIGHT SENSITIVE W/OUTSIDE TEMP & COMPASS
DK6 - OVERHEAD CONSOLE DL8 - OSRV DUAL POWER HEATED MIRRORS
D07 - CUSTOM FRONT FLOOR CONSOLE EVA - EVAP EMISSION REQUIREMENT
E63 - FLEETSIDE BODY FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS
FK2 - TORSION BAR SPRING ADJUSTMENT FK3 - TORSION BAR SPRING ADJUSTMENT
GT4 - REAR AXLE - 3.73 RATIO G80 - LOCKING DIFFERENTIAL-REAR AXLE
JC5 - 4 WHEEL POWER DISC BRAKES KNP - HD AUX TRANSMISSION COOLING SYS
K34 - CRUISE CONTROL K47 - HIGH CAPACITY AIR CLEANER
K68 - 105 AMP DELCOTRON GENERATOR LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHEEL NP8 - AUTOTRAC ACTIVE TRANSFER CASE
NZZ - OFF-ROAD SKID PLATE PACKAGE OSG - OSHAWA ASSEMBLY
PCM - ELECTRICAL CONVENIENCE PACKAGE PDD - COLOR-KEYED CARPET
PF9 - CAST ALUMINUM WHEELS QGD - P265/75R16-114S ALT WOL TIRES
SLM - STOCK ORDERS T96 - FRONT FOG LAMPS
UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL 1 YR SAFE & SOUND PLAN UP0 - AM/FM STEREO W/CASS & CD PLAYER
UQ3 - ENHANCED AUDIO SPEAKERS UY7 - HD 7-LEAD TRAIL. WIRING HARNESS
VB3 - CHROME REAR STEP BUMPER VG3 - FRONT DELUXE CHROMED BUMPER
VR4 - WEIGHT DISTRIB. PLATFORM HITCH VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE PKG. V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGD - P265/75R16-114S ALT WOL TIRES X88 - CHEVROLET CONVERSION
YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD6 - BASE REAR SPRING
YE9 - SILVERADO YGD - P265/75R16-114S ALT WOL TIRES
ZGD - P265/75R16-114S ALT WOL TIRES ZY1 - SOLID PAINT
Z71 - Z71 EQUIPMENT PACKAGE Z82 - HEAVY DUTY TRAILERING EQUIPMENT
1SC - LT DECOR INCLUDES: * AIR CONDITIONING WITH AIR FILTRATION SYSTEM * ISRV MIRROR W/COMPASS & TEMP * DUAL PWR HEATED OSRV MIRRORS * REAR WINDOW DEFOGGER * DEEP TINT GLASS * AUTOTRAC ACTIVE TRANSFER CASE * FRONT FOG LAMPS * AM/FM STEREO W/CASSETTE & CD * CHROME GRILLE * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * LEATHER WRAPPED STEERING WHL * CAST ALUMINUM WHEELS * BODYSIDE MOLDINGS * 6-WAY POWER HEATED BUCKET SEATS W/FRNT LEATHER SEATING SURFACES & DRIVER MEMORY * ONSTAR COMMUNICATIONS SYSTEM INCL 1YR SAFE & SOUND PLAN 1SZ - EQUIPMENT SAVINGS *MANUAL TRANSMISSION DISCOUNT
12I - GRAPHITE INTERIOR TRIM 122 - GRAPHITE CUSTOM LEATHER TRIM
14U - MED CHARCOAL GRAY METALLIC 6YH - COMPONENT FRT LH COMPUTER SEL
7YH - COMPONENT FRT RH COMPUTER SEL
Old Sep 23, 2008 | 09:30 AM
  #538
1GCEK14T34Z113288
Looks pretty sound and clean to me bro.
VEHICLE INFORMATION
Merchandising Model : CK15703 -2004 SILVERADO 1500 4WD REG CAB Z71 Warranty Start Date : 09/17/2004
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : RELIABLE CHEVROLET
PO BOX 831240
RICHARDSON , TX 75083-1240
(972) 952-1500
Selling Source : 13 - CHEVROLET
Site Code : 07706
Business Associate Code : 112311
Type Number Description Posted Date Status
RC 04007 TAILGATE SUPPORT CABLE N/A Closed
OnStar Equipped No OnStar Status N/A Refer to Help page for details or:go to OnStar Online Enrollment (located on the "OnStar" tab in GM InfoNET) or (888)ONSTAR1 (888) 667-8271.
XM Equipped Yes XM Radio ID AUT020CL XM Status Inactive Refer to Help page for details or: www.xmradio.gm.ca or Dealer Hotline 1.877.GET.XMST (1-877-438-9677).
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 09/17/2004 146 miles 09/17/2007 36146 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/17/2004 146 miles 09/17/2010 100146 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/17/2004 146 miles 09/17/2012 80146 miles
36/36000 FEDERAL EMISSION 09/17/2004 146 miles 09/17/2007 36146 miles
CLAIM HISTORY
01/06/2006 307230 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 23212 miles
01/06/2006 307230 # C4283 - MOLDING, BACK WINDOW GARNISH - LOWER - R&R OR REPLACE 23212 miles
09/27/2004 123134 # A0357 - HOOD REFINISH/CLEAR COAT 435 miles
09/16/2004 122294 # B4051 - LINK OR SPRING, FRONT DOOR HOLD OPEN - LEFT - REPLACE 142 miles
09/16/2004 122294 # B4050 - LINK OR SPRING, FRONT DOOR HOLD OPEN - RIGHT - REPLACE 142 miles
07/29/2003 A13288 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME
Old Sep 28, 2008 | 03:51 PM
  #539
02slow4.8's Avatar
hey.... think i could get the a build sheet, history and recalls on this vin... thanks!!
1GCEC14V82Z236936
Old Sep 29, 2008 | 07:04 AM
  #540
1GCEC14V82Z236936
One build sheet coming up! Here ya go friend....hope you find this helpful.
VEHICLE BUILD
Merchandising Model : CC15703 -2002 SILVERADO LS 1500 2WD REG CAB
Gross Vehicle Weight Rating : 2769 kg (6106 lb) Order Number : DSBRF6
Build Date : 01/18/2002 Build Plant : 12Z03
OPTION CODES
AE7 - 40/20/40 SPLIT BENCH SEAT WITH 6-WAY POWER AND FRONT LEATHER SEATING SURFACES AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER
B3P - BAILMENT COMMERCIAL VEHICLE B30 - WHEELHOUSING & FLOOR CARPETING
B32 - FRONT COLOR-KEYED FLOOR MATS B85 - BRIGHT BODY SIDE MOLDINGS
C5M - 6,100 LB GVW RATING C60 - AIR CONDITIONING WITH AIR FILTRATION SYSTEM
DK7 - INTERIOR CUSTOM ROOF CONSOLE D48 - ELECTRIC EXTERIOR MIRRORS
EVA - EVAP EMISSION REQUIREMENT E62 - SPORTSIDE BODY
FE9 - FEDERAL/NY/MA/ME/VT EMISSIONS FWI - FORT WAYNE PLANT
GU6 - REAR AXLE 3.42 RATIO JC5 - 4 WHEEL POWER DISC BRAKES
K34 - CRUISE CONTROL K68 - 105 AMP DELCOTRON GENERATOR
LR4 - VORTEC 4800 V8 SFI GAS ENGINE M30 - 4-SPD AUTOMATIC TRANSMISSION WITH TOW HAUL MODE
NF2 - FEDERAL EMISSION SYSTEM NP5 - LEATHER WRAPPED STEERING WHEEL
PDD - COLOR-KEYED CARPET PY2 - CHROME STEEL WHEELS
P03 - CHROME CENTER WHEEL CAPS P2A - SPECIAL PAINT - ONE COLOR (A)
QNG - P235/75R16 ALS WOL TIRES SLM - STOCK ORDERS
TGK - SPECIAL PAINT PROCESS OPT-SOLID UN0 - AM/FM STEREO W/CD PLAYER & ATC
UQ3 - ENHANCED AUDIO SPEAKERS VB3 - CHROME REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER VXS - COMPLETE VEHICLE LABEL
XNG - P235/75R16-106S ALS WOL TIRES X88 - CHEVROLET CONVERSION
YE9 - SILVERADO YK6 - SEO IDENTIFICATION
YNG - P235/75R16-106S ALS WOL TIRES ZNG - P235/75R16-106S ALS WOL TIRES
Z83 - STANDARD CHASSIS PACKAGE 01U - SPECIAL PAINT
1SB - LS DECOR INCLUDES: * AIR CONDITIONING W/AIR FILTRATION SYSTEM * DUAL POWER MIRRORS * CHROME GRILLE * ELECTRONIC SPEED CONTROL * POWER LOCKS & WINDOWS * REMOTE KEYLESS ENTRY WITH CONTENT THEFT ALARM * LEATHER WRAPPED STEERING WHL * BODY SIDE MOLDINGS * 40/20/40 SEATING W/RECLINE AND ARMREST STORAGE 1SZ - PREFERRED EQUIPMENT SAVINGS (NOTE-THIS PREFERRED EQUIPMENT GROUP SAVINGS IS RESTRICTED TO RESIDENTS OF TEXAS, OKLAHOMA, LOUISIANA AND SELECT COUNTIES IN NEW MEXICO. PLEASE CONSULT YOUR DEALER FOR ELIGIBILITY REQUIREMENTS.)
12D - GRAPHITE CUSTOM CLOTH TRIM 12I - GRAPHITE INTERIOR TRIM
6MS - COMPONENT FRT LH COMP. SEL SUSP 7MS - COMPONENT FRT RH COMP. SEL SUSP
