Check Re-Calls & Service History Here
#42
Originally Posted by LARRY01Z28
can one of you guys look mine up. 99 silverado 2G1FP22G912127009 thank you very much. larry
Hope this helps.
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/02/2001 093393 # F3200 - REAR DIFFERENTIAL ASSEMBLY (COMPLETE) - REPLACE 19808 miles
03/28/2001 023575 # J6360 - POWERTRAIN CONTROL MODULE REPLACEMENT 6780 miles
03/23/2001 023547 # J5650 - INJECTOR, FUEL - REPLACE 6526 miles
11/15/2000 A27009 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#43
Originally Posted by CHEVRACER83
THINK YOURS IS BAD.... HERES MINE
WORKING AT A DEALER I GET ALOT OF CRAP DONE...
ADD INTERMITTENT TRANS PROBLEM TO THE LIST TODAY....
I DONT HAVE A TRANS PROBLEM... BUT IM GETTING IT WRITEN UP SO MY TRANS GUY CAN FLAG SOME TIME FOR PUTTING IN MY BILLET SERVOS, AND MY TRANSGO SPACER PLATE..... ALL COURTESY OF FLT!!!!
EDIT: IF YOU LOOK CLOSELY ONE OF MY TECHS FLAGGED A FUEL FILTER CHANGE.... YET MY TRUCK DOESNT HAVE A FUEL FILTER
I LAUGHED MY *** OFF WHEN I SAW THAT
04/30/2007 528328 # D3082 - HOSES AND/OR LINES, REFRIGERANT - COMPRESSOR DISCHARGE - R 20570 miles
04/19/2007 527436 # E9050 - PUMP ASSEMBLY, POWER STEERING - REPLACE 19651 miles
04/13/2007 527191 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 19451 miles
04/13/2007 527191 # E7012 - SWITCH AND/OR CONTROL, STEERING WHEEL MOUNTED - REPLACE 19451 miles
04/02/2007 526245 # H0042 - PADS, DISC BRAKE - FRONT - R&R OR REPLACE 18552 miles
02/08/2007 522152 # J9991 - CUSTOMER CONCERN NOT DUPLICATED 14266 miles
01/03/2007 519321 # J0990 - PLUG AND/OR GASKET, OIL PAN DRAIN - REPLACE 11638 miles
12/20/2006 518425 # J5420 - FILTER, FUEL ELEMENT - REPLACE 10733 miles
12/20/2006 518425 # J9995 - CUSTOMER CONCERN NOT DUPLICATED 10733 miles
03/24/2006 A71257 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
#44
Originally Posted by Torque_Wrench
lol...Racer...that's classic! I do the same thing...well...err...I did when my ol' bitch was under warranty. See...it's proof that great minds think alike!
EITHER THAT OR WERE BOTH CROOKED AS *****
#47
swwet man thank you.
#49
Originally Posted by TurboGibbs
Can you tell me all the options/build data on this vin# 1G6DM57T260160377
VEHICLE BUILD
Merchandising Model : 6DM69 -2006 CTS 2.8L V6 VVT
Gross Vehicle Weight Rating : 2081 kg (4589 lb) Order Number : JRDSNS
Build Date : 12/01/2005 Build Plant : 160D
OPTION CODES
AQ9 - SEAT FRT BKT, LUXURY AY0 - INFLATABLE RESTRAINT DRI & PASS
CJ2 - HVAC FRT. AUTO TEMP/AUX TEMP DL5 - DECAL - ROADSIDE SERVICE INFO
DR5 - MIRROR O/S REMOTE L/H R/H FE1 - SUSPENSION SOFT RIDE
FE9 - 50-STATE EMISSIONS GT4 - AXLE REAR 3.73 RATIO
ILW - INTERIOR TRIM JJA - PT DRESS SUBASSEMBLY INSTALLED
JL9 - ANTILOCK BRAKE FRT & REAR KG9 - GENERATOR 140 AMP
LP1 - 2.8L V6 DOHC ENGINE MN6 - TREMEC 6-SPEED MANUAL TRANS
MV1 - AISIN, 6-SPEED MANUAL TRANS NP5 - LEATHER WRAPPED STEERING WHEEL
NT7 - EMISSION - FEDERAL PF4 - 16" ALLOY WHEELS
QWJ - P225/55R16 ALL SEASON/H-RATED R6P - PREMIUM PAINT
SLM - STOCK ORDERS UE1 - ONSTAR COMMUNICATIONS SYSTEM INCL. 1 YR SAFE & SOUND PLAN
U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. U2R - AM/FM STEREO/CAS/IN-DASH SINGLE CD, RDS
U30 - INSTRUMENT CLUSTER,TACH,CLOCK U66 - 7 SPEAKER SYSTEM
V73 - VEHICLE STATEMENT USA/CANADA 1SA - CTS STANDARD PACKAGE
1SZ - PREFERRED EQUIPMENT SAVINGS 13I - LIGHT GRAY/EBONY
13W - LIGHT GRAY 6MR - SUSPENSION
7MR - SUSPENSION 71U - BLACKBERRY
8FR - COMP RR LH COMPUTER SEL SUSP 9FR - COMP RR RH COMPUTER SEL SUSP
